ECU output to Tachometer. Is it in volts?
Old Mar 31, 2002 | 11:38 AM
the_saint's Avatar
Arrow ECU output to Tachometer. Is it in volts?
I am trying to datalog my RPMs, but I need a voltage output.
Is the signal from the ECU to the tachometer a voltage signal?
Which wire should I tap into?
Or do I need to get another tach circuit board and read off of that?
Thanks
thesaint
p.s. for whoever is interested I am planning on datalogging my MAP voltage, wideband o2 sensor output, and rpms to tune the car.
Along that note, does the InterAcq software for the EFI PMC allow you to log other inputs? As far as i understand all possible inputs to the PMC are already used.
Old Mar 31, 2002 | 05:04 PM
the_saint's Avatar
Question
ttt
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
imitek
Oct 18, 2015 03:35 PM
ZacMan
Sep 19, 2015 09:20 PM
astrum
Sep 7, 2015 11:41 PM
