Microtech idle issues
Old Jun 25, 2007 | 01:13 PM
Rotorhead34's Avatar
Scream baby Scream!!!
idle issues
Okay, I have the car running, but not well. I have 750cc primary, 1000cc secondary, T04E ar60-1/ .98 on the hot side. Microtech LT10s, x4 and the hand controller. All is hooked up and seems to be reading all the values, although, they are still in need of adjustment. I'm having trouble getting the car to idle. The lowest I got it to idle was 1250rpms. Anything lower than that, it will bog until it dies. I haven't been able to set the timing yet because of the idle. I'm not in full understanding of the what the values mean on the screen of the hand controller. the 30hg; whats the hg mean and the 1.43;?
Also, I read in hear somewhere about moving the cas one tooth to set the timing? I did notice last night the hand controller was reading my timing and it would flucuate between 15BTDC and 20BTDC depending on the rpms of course at idle. I didn't pay much attention to it yet as I haven't got far enough to lock the timing to set it. Just wanted to know if this is still the practice of setting the timing.
I did notice that the afr was around 11. Is this right? I thought it was better closer to 14.
I'm just trying to get it good enough to go to the dyno. Thanks
Old Jul 4, 2007 | 12:02 AM
rx72c's Avatar
Top Answer: 1
sounds like your tps is out.
when no throttle is being applied tps needs to be on 0.
idle afr to get it smooth will be around the 12 mark.
and idle timing should be between 0 and 5 degrees on anything but a bridgeport or PP.
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
troym55
23
May 25, 2016 12:42 PM
83revival
Sep 3, 2015 10:42 PM
