how to run carb through injector
Old Mar 30, 2002 | 08:19 PM
von's Avatar
von
I already connected the bat to the inj. so it clicks but thiers no pressure for the fluid to run through.
Also whats the difference in looks between the n/a injectors and t11 injectors
Old Apr 1, 2002 | 06:46 AM
NZConvertible's Avatar
I'm a boost creep...
Don't **** around trying to clean injectors at home. Nothing you can do will come close to the results of having them professionally cleaned. It doesn't even cost much.
Old Apr 1, 2002 | 08:24 AM
Vroomaster's Avatar
"It doesn't even cost much."
$50-$60 per pair around here, that's not cheap.
If you know places for cheaper, please let me know.
NAPA doesn't clean injectors here.
Old Apr 2, 2002 | 12:29 PM
Vroomaster's Avatar
OK, so what's the best method to clean your injectors at home? Anyone?
Old Apr 2, 2002 | 04:38 PM
Vroomaster's Avatar
Old Apr 2, 2002 | 06:27 PM
RexRyder's Avatar
run carb cleaner thru your engine
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
eddierotary
Aug 16, 2015 04:12 PM
