Strange ?'s about my EGI main relay. This just dosent make sense....
Old Mar 30, 2002 | 06:24 PM
ItsNiceToBurnRice's Avatar
I was messin with my fuel cut switch today, and then for some reason my car wouldnt start. I jumped my fuel pump and it wont make a sound. So I listened for the relay to click, and it wasnt. I pulled it out and put power to it, this makes it click. So then I kept the power to it and plugged the 4 wire harness in, still no fuel pump whir. I check the continuity of the relay, and nothing, no sparks when I touch them together. So then I got stupid and decided to stick a wire in the power connecter that comes from the car that goes into the relay, no spark. What the hell? Even if I wasnt getting power to the relay, (which would explain it not clicking), I still hooked it up with power straight from the battery that made it click. I even took out my buddys main relay and got the same exact results,(but his car hasnt started for a year). All this after just messing with my switch. What could be going on here, Im stuck. Any help is much appreciated.
Old Mar 30, 2002 | 07:05 PM
Who ever can answer this ? is the true rx master.
Old Mar 30, 2002 | 07:16 PM
HAILERS's Avatar
HAILERS
Probably the 15a fuse in the cockpit. Third row up from the bottom, second from the left. If thats not it, Irv(keith) will know.
Old Mar 30, 2002 | 08:29 PM
God Bless Hailers
Hailers, you are the man, funny thing is I thought I checked every fuse in there. DOH!(smiley face wouldnt come up)
Rotospectre
Mar 28, 2018 03:33 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
rexone
The Bad & Fugly Businesses
Aug 23, 2015 06:24 AM
