Midwest RX-7 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS
need more power!
Old Jun 21, 2007 | 09:23 PM
jd89's Avatar
need more power!
I have a 83 fb with a RB header, holley 465 carb and intake, after market exhuast, mallory fuel pum, msd blaster 2 coils and wires. like i said i need more power. Help would be great thanks guys
Old Jun 22, 2007 | 03:56 PM
kgray's Avatar
GOT WANKEL?
Finish out the exhaust.
MSD 6A box.
2nd Gen coil.
Turbo.
Nitrous.
Tune carb with wideband.
Old Jun 22, 2007 | 10:37 PM
jd89's Avatar
MSD 6A box.
2nd Gen coil.
Turbo.
Nitrous.
Where do i get this stuff at i can't find a turbo kit for my 7
And how do i hook up the 2nd gen coil to a 12a motor where do i find the msd6a box? thanks though
Old Jun 22, 2007 | 11:46 PM
KSTIIdude's Avatar
Based on your description of your car, you are at a point where you either need porting work on your engine, or forced induction to make any noticable gains.
Old Jun 23, 2007 | 01:42 AM
Sgt.Stinkfist's Avatar
premix, for f's sake
for the most part you wont find a turbo kit for the first gen, unless you come across a kit from the 80's which are a rare find and usually not in good working order, nor complete. If you want boost you need to do a good amount of custom fabrication and make your own turbo kit. as for the ignition, chose either the 2nd gen coil OR an MSD setup, not both. the MSD boxes can be bought from jegs/summit. check the first gen section, there are good right ups for both ignition mods. good luck
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
