Gas Leak?
Old Mar 29, 2002 | 11:21 PM
damn hippies
Gas Leak?
i was driving on the highway for a few miles when i got off it seemed harder to keep idle than before (dosnlt like to idle) anyways im at a stop sign and it dies, i wouldnt start up and gas was leaking along the driver side door, it didnt seem like it had fule pressure, would you figure it be fule pump or a hole in the fule line? any ideas at all
Stepdaddy
Old Mar 29, 2002 | 11:33 PM
damn hippies
Bump for the love of god, i might need to add that the oil gadge was 0'ed for about 2 miles, didnt get any hotter though
Old Mar 29, 2002 | 11:36 PM
MasteRX's Avatar
More Than Meets the Eye
The fuel lines run along the drivers side, so I would first check the hoses and fuel filter under hood, then jack the car up and take a look underneath. Hopefully it is just a hose or the filter, so it is easy to replace.
As far as the oil guage goes, unless you were out of oil, you most likely had a problem with the oil sender, or the wire that goes to the sender came off. It is unlikely that the oil pump gave out in my opinion. But you should never be running with out any oil pressure, you should have pulled over to check right away.
Old Mar 30, 2002 | 05:03 AM
damn hippies
aww, i was afrade of that im ganna check to see if any vacumes hoses are off then when i get home from work the fule lines and filter
Old Mar 31, 2002 | 06:12 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
if it goes down the drivers side door it prolly isnt the PD huh?
Justin
Old Mar 31, 2002 | 07:24 PM
damn hippies
im not sure all the abreviations, can someone tell me PD-TIP-and other crazy slang term
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
