Sponsored by: CARiD
High compression rotors
Old Jun 16, 2007 | 12:06 PM
Meatkibble's Avatar
Cruisin in the whip
Ok, ive looked around and i will be honest, i probably just didnt see it, however my question is this. Are there higher compression rotors I could put into my s5 n/a? If so, what is the compression, and maybe a link to the seller/company/distributor's website.
thanks
chris
Old Jun 16, 2007 | 01:40 PM
eddierotary's Avatar
back with rotaries
rx8 rotors they are 10:1 ratio. you can get them at mazdatrix cheaper thta the S5 ones
Old Jun 16, 2007 | 07:43 PM
st1llet0's Avatar
And the benifits of higher than stock compression?
Old Jun 16, 2007 | 10:39 PM
initial D is REAL!'s Avatar
same for any other engine, more power, but high octane is a must
Old Jun 18, 2007 | 11:40 AM
Meatkibble's Avatar
Cruisin in the whip
will the rx8 rotors fit straight in the s5 housing? Because i might be mistaken, but i don't think they will be straight bolt on.
Old Jun 18, 2007 | 12:20 PM
diabolical1's Avatar
there is no problem with physical fitment. there are going to clearance issues that you have to address with bearings and side seals though.
troym55
23
May 25, 2016 12:42 PM
