Microtech Tachometer reading is half than the microtech says...
Old Jun 15, 2007 | 07:06 AM
MaczPayne's Avatar
Mac Attack
My microtech is configured correctly at 4 cyl for a 2 rotor engine, the idle is 750, but my tachometer is barely registering, I have it hooked up at the stock position, what else could be the problem?
Old Jun 15, 2007 | 01:19 PM
Aaron Cake's Avatar
Engine, Not Motor
Check the wiring around the trailing coil plug. If it's in poor condition or the plug is dirty, the tack will be random...
Old Jun 15, 2007 | 02:37 PM
RotaryEvolution's Avatar
Sharp Claws
the tach itself could also be damaged from a voltage spike if it was incorrectly wired up initially.
Old Jun 18, 2007 | 12:45 AM
MaczPayne's Avatar
Mac Attack
Okay, I found out what was wrong. Apparently my trailing coils aren't firing, so I'm only getting readings from the leading coil. I have power to the microtech, and I am doubly sure that I wired the trailing coils correctly. I checked, double checked, and triple checked them. I'm gonna see if I can get a set of working coils to see if they work.
Old Jun 26, 2007 | 10:08 PM
MaczPayne's Avatar
Mac Attack
Fixed the problem.
Someone had set the spark trigger to negative when it was supposed to be +maz.
freq
Haltech Forum
Sep 13, 2015 07:45 AM
doritoloco
Sep 5, 2015 12:41 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
rx7shirley
Sep 2, 2015 02:11 PM
