90 rx-7 convertible
Old Mar 29, 2002 | 03:03 PM
amedina's Avatar
90 rx-7 convertible
Should I empty the Cat on my 7 without any other modification?
Old Mar 29, 2002 | 03:05 PM
go_speed_go's Avatar
Be fore-warned you could be in for some stinky driving.
Covnertible owners who've removed the cats complain of the exhaust smell when the car is sitting still.
Old Mar 29, 2002 | 03:22 PM
amedina's Avatar
Does it do anything for performance and heat reduction?
Old Mar 29, 2002 | 03:33 PM
You will get more power.
It will be a question as to if your eyes aren't tearing so much that you'll be able to use it.
Old Mar 29, 2002 | 04:59 PM
MasteRX's Avatar
More Than Meets the Eye
If you clear out your cats, your 5th and 6th ports wont open, they need a little bit of exhaust backpressure to open. So to maximize top end power you will have to wire them open. By doing this you will suffer on low end power though.
Old Mar 29, 2002 | 10:29 PM
vaughnc's Avatar
knowledge junkie
amedina,
For my 89 convertible I added:
- a downpipe to replace the pre-catalytic converter
- Added a performance catalytic convert.
- HKS catback exhaust
Sounds good, smells good, restores power.
Great upgrade
Old Mar 29, 2002 | 10:42 PM
My Junx's Avatar
Rotary Father
Nope, it's a '90, so the lack of backpressure has zero effect on the ports opening, that is done via the air-pump. But if you gut the cats you will have some strong fumes getting pulled back into your car, especially with the top down and sitting still. You will get a little extra power though. I have no cats on my 90 GXL and with the windows down in traffic sometimes my eyes really sting Gotta love that rotory engine.
Old Mar 29, 2002 | 10:59 PM
vaughnc's Avatar
knowledge junkie
Yes - if you add a "downpipe" and a "straighpipe" so you have an open exhaust - it will make your eyes water if you're behind the car.
Not to mention the cops will pull you over for the excessive noise.
Useing a performance main cat & downpipe is the best setup on power/legality/exhaust note/good smell.
Old Mar 29, 2002 | 11:30 PM
ponykiller's Avatar
I have a 91 convertible that I am running a small aftermarket Jeep catalytic converter on. I was just using straight pipes, but the smell was awful (I ALWAYS have the top down, and could not stand the smell anymore). I am still running stock mufflers, but the lack of cats blew them out, so they are a fair bit louder now (but by no means anoying). I would definately chop the stock cats, because after about 70,000 miles, they become a brick. And, as we all know, bricks do not flow exhaust gases very well.
Kris
Old Apr 18, 2002 | 02:31 PM
amedina's Avatar
Thanks to all of you for your responses. I just put in a new 13b. What are some quick ways to get some more HP out of the engine easily without too much modification?
Thanks!
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
