Coilovers....
Old Mar 29, 2002 | 01:16 PM
BlackRx7's Avatar
Daily Domestic Killer
Coilovers....
what are the advantages of a coilover setup rather than the stock setup? Does it allow you to adjust caster/camber, I know the stock setup only has 1/2 of degree of adjustment, how much adjustment do the coil overs offer?
finally how much do they usally cost, and what are some good vendors...
Old Mar 29, 2002 | 01:19 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the coil overs let you adjust the height of the car at each wheel. if you buy camber plates with them you can adjust the front camber. you need a rear camber link to adjust the rear camber. I just picked up the www.k2rd.com kit which comes with KYB AGX shocks, coil overs, front camber plates, and rear camber link for $950.
http://www.1300cc.com/howto/how2/springs.htm
Old Mar 29, 2002 | 01:22 PM
RETed's Avatar
My personal reasons for going with the coilovers is 1) you change spring rates relatively easily and cheaply (~$100 per pair), and 2) you can corner balance the chassis.
-Ted
anees
Nov 24, 2010 10:49 PM
Messinian7
Dec 27, 2007 02:51 PM
Slammedblk7
37
Aug 23, 2005 02:41 PM
