turboing a n\a motor
Old Jun 11, 2007 | 11:24 PM
0249680's Avatar
Newbie
where do i get the oil from the engine to supply the turbo? the cooling lines are no problem but where to get the oil from?? and maybe the return. but if all fails i can tap the oil pan for the return return.
Old Jun 11, 2007 | 11:33 PM
dothacker's Avatar
maybe replacing the NA oil pan with a T2 oil pan would work. I never had any intentions of turboing my N/A so i can't get a straight answer.
Old Jul 19, 2007 | 01:21 AM
quasar's Avatar
I'm in rotary heaven!
If you actully do this I recomend disassembling your engine than drilling holes to avoid any metal files going in critical areas of the engines internals.
Remember, this is just a suggestion. Work at your owne risk.
Old Jul 19, 2007 | 03:24 AM
1.3mazda's Avatar
HOT DOGS! 8======D
or just use a same series (s4na=s4turbo, s5na, s5turbo) front covers!
Old Jul 19, 2007 | 03:25 AM
1.3mazda's Avatar
HOT DOGS! 8======D
good recommendation, but also a rather expensive one at that, cheapest seal kit that i have ever found for a 13b was like right under $300 shipped, nothing like a 12a cause felpro makes a seal kit for the 12a for like $130, dont know if i would use felpro for a rotary considering they didnt continue making gasket kits for the 13b,13bt, 13b-rew, etc. and so on.....
Old Jul 19, 2007 | 06:28 AM
quasar's Avatar
lol, I just use the grey rubber sealant from mazda.
Old Jul 19, 2007 | 09:38 PM
0249680's Avatar
Newbie
thanx
thouse pic really will help i have 2 motors and i whant to turbo my spare motor just for fun and swap the motors out and see how much HP i push with 10:1 stock compression but the motor has a blown seal so i am in the mists of rebuilding it.
Old Jul 19, 2007 | 09:50 PM
rxmclaren7's Avatar
Blazin' 87 N/A
i had no idea you could turbo the n/a motor. i was told that you will run into way to many problems than its worth. now ive got ideas...hehehehehe. also what about supercharging the n/a motor?
Old Jul 19, 2007 | 10:03 PM
SASSER's Avatar
Calm like a bomb
SCing a n/a rx7has been proven and covered over and over that it doesn't work and the gains are a waste of money. Turboing an n/a needs some fab work and knowing what your doing to make it cheaper than it would be to buy a T2 motor and swap it in.
Old Jul 20, 2007 | 03:50 PM
quasar's Avatar
Dont forget to cut out the baffle in the exhaust port and perminently keep the 6 port barrels open. You can have some fun doing this but dont expect alot of miles out of it. I haven't had much luck over 4 lbs as a dailly driver but it can be done for s short perriod of time. If you can come across a set of S4 turbo roters stick them in there and you can do basicly what ever you want but it still wont run as good as the 4 port irons.
Old Jul 20, 2007 | 04:12 PM
WrEcK-LeSs's Avatar
Just use an oil pedestal and some an line. run you under a 100 bucks. Also heres a bunch of good links for info
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/turbo-oil-passage-flanges-buy-them-where-507052/
http://www.aaroncake.net/RX-7/naturbo.htm
http://forum.teamfc3s.org/showthread.php?t=37694
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/using-n-engine-harness-turbo-possible-608551/
http://www.homemadeturbo.com/forum/i...&topic=28135.0
cristoDathird
28
May 30, 2019 08:47 PM
