Haltech ATTENTION!! Introducing the New Universal PnP Haltech Kits!!
Old 06-11-07, 12:48 AM
EFI Tech Wannabe
Claudio RX-7's Avatar
Ladies and Gentlemen, i am proud to announce the introduction of my New Universal PnP Haltech Plug In Kits!!!. These new kits will allow you to install ANY Haltech system onto your vehicle using your existing vehicle's harness minimizing installation times and making this a clean install.
With this kit you will be able to install your Haltech Plug N Play style to the following vehicles (please note that on some applications, you will need to order an additional MAP sensor, air and coolant temp sensors):
Unit Kit Applications ODB1
Car Make/Model Suited Year
Honda/Acura (all obd1) 92-96
Acura NSX 91-95
Mitsubishi 3000GT 92-98
Mitsubishi EVO 1-8 All
Mitsubishi Eclipse 95~
Mitsubishi 3000GT 93-96
Mitsubishi Galant 96~
Subaru WRX 93-96
Subaru WRX 97-98
Subaru Legacy 91-96
Mazda RX-7 FC 89-91
Mazda Cosmo 90-96
Mazda RX-7 FD 93-97
Mazda Miata 99
Mazda 323 98-02
Toyota MR-2 90-96
Toyota Celica 89-96
Toyota Supra MK3 90-92
If anybody knows of vehicles with this same styled of connector that isnt listed here, please send me a pic of the ECU's main connector so i can confirm if this patch harness works on it and i will add it to the list.
Right now you will basically be getting something like this, but unspliced, you will have to do a little leg work on this. A generic Wiring Diagram will be provided so you know exactly what to do, and i will provide wiring diagrams on applications i can get them for. If you have an application for this and you have the wiring diagram, please send it to me and i will tell you what to do.
Nissan OBD1 plug in patch harness will be available soon! This will fit this particular ECU versions:
More to come soon!! I plan to develop new plug in patch looms so that i can supply them for other brands of vehicles too, like VW/Audi obd2, Subaru obd2, Toyota obd2, Nissan obd2, etc., as availability for the main connectors is somewhat difficult, if anybody has an application they'd like to see produced, and you have a line on where to get the main connectors for the ECU and harness, please let me know and i will look into it.
Old 06-11-07, 01:04 AM
'Tuna'
crispeed's Avatar
I should have my first one here today for the 2jz to test.
I'll let you know how it works out.
Old 06-11-07, 09:49 AM
YayeR's Avatar
lol @ ODB1
Quick question: It looks like your kits are keeping the stock ECU for some functions. Is that correct?
Old 06-11-07, 11:13 AM
EFI Tech Wannabe
Originally Posted by YayeR
lol @ ODB1
Yes Sir! i feel that its pointless to waste an input and an output on things like the AC, you can also let the stock ECU control things like the dash/gauges, as well as plenty of grounds and positive leads that run through it.
Its all a matter of just tapping the wires you need for power and ground for the haltech, and intercepting the crank/cam sensors, temp sensors (with the E8/E11), in the case of the E6X you dont even need a map sensor to start, and with the cars that have air flow meters you can basically just get rid of that all together when using the Haltech to control the engine.
It even works on DBW (drive by wire) cars.
Old 06-15-07, 07:10 PM
EFI Tech Wannabe
Update!!
Guys, Universal DIY PnP for Obd1 style ECU's is ready to ship!!!
Here is what you get with the kit:
Your Choice of ECU (F10X/E6X/E8/E11v2)
Short Flying lead Harness to suit ECU
Optional Sensors (both metric and NPT available)
Obd1 styled patch connector
Suited for these Vehicles:
Acura NSX 91-95
Subaru WRX 93-96
Subaru WRX 97-98
Subaru Legacy 91-96
Mazda RX-7 FC 89-91
Mazda Cosmo 90-96
Mazda RX-7 FD 93-97
Mazda Miata 99
Mazda 323 98-02
Toyota MR-2 90-96
Toyota Celica 89-96
So, join in! now is the time! More applications will follow soon! Contact me for more details!
Thanks.
09-16-18 07:16 PM
SakeBomb Garage
SakeBomb Garage
09-04-15 05:20 PM
SakeBomb Garage
Vendor Classifieds
09-04-15 05:19 PM
Quick Reply: Haltech ATTENTION!! Introducing the New Universal PnP Haltech Kits!!
