All 2nd gen fuel pumps can be replaced with the FD fuel pump for higher flow.
Old Jun 9, 2007 | 10:36 PM
CarzArKoo1's Avatar
Thumbs up All 2nd gen fuel pumps can be replaced with the FD fuel pump for higher flow.
All 2nd gen fuel pumps can be replaced with the FD fuel pump for higher flow. It is a direct drop in
What is the benefit of this, I got this from http://www.aaroncake.net/RX-7/random.htm
thanks
Old Jun 9, 2007 | 11:01 PM
NZConvertible's Avatar
I'm a boost creep...
It's a good upgrade for mildly modded Turbos, but completely pointless and counterproductive for NA's.
Old Jun 10, 2007 | 12:29 AM
CarzArKoo1's Avatar
Coo! thanks for clarifying this.
Old Jun 10, 2007 | 02:46 AM
RETed's Avatar
Wow, a 10% to 15% increase in fuel capacity over an FC turbo unit...
Walbro is cheaper (brand new) and outflows the FD unit.
Oh snap...
-Ted
Old Jun 10, 2007 | 05:44 AM
A Walbro will cost me ~NZ$200, while my FD pump cost NZ$50.
Did something snap? Better fix it...
Old Jun 10, 2007 | 06:09 AM
Eternal_Gamer's Avatar
what about the supra tt pump, its a lot cheaper now.
Old Jun 10, 2007 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
What they said. All the FD and FC pumps can be swapped around for flow changes. The FD pump is a cheap and easy change for a mildly modded FC and you don't have to deal with things like increased fuel rail pressure that the big Walbro can handle...
Old Jun 10, 2007 | 12:53 PM
tim g's Avatar
Aaron you also say that all motor mounts are the same, the only difference with the vert is the stiffness of the mount. If I buy full comp stiffness mounts they'll drop right in? Thanks!
Old Jun 10, 2007 | 08:16 PM
Aaron Cake's Avatar
Engine, Not Motor
Correct. The 'Vert mounts are supposed to be stiffer for some reason.
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
