Sponsored by: CARiD
rotary diesel..?
Old Jun 7, 2007 | 02:53 PM
user 8202's Avatar
rotary diesel..?
so im doing some research as im typing this and was wondering..
has any of u guru's do a diesel conversion yet.. if so who.. i think it would be such an awsome idea.. better gas milage for those who like to daily drive it .. or less gas pit stops on the track.. alos i think it would be smog exempt as well, now how cool would that be! especially for us californians and dick head refs.. ..
here is some of my findings..
http://www.machinedesign.com/ASP/str...tedArticle.asp
http://www.smartplugs.com/engines/ro...nglerotary.htm
i am no hardcore tuner but am mechanically inclined... just how hard would it be to convert a rotary engine to diesel..?
Old Jun 8, 2007 | 01:21 PM
ermin277's Avatar
IT's been done. check out www.smartplugs.com they have a one rotor on there running on diesel. they direct inject the fuel through one of the spark plug holes. they should turbo it on a two rotor and give some HP figures. I bet their system has problems running at higher RPM's though.....
-spence
Old Jun 8, 2007 | 01:41 PM
ermin277's Avatar
also check out http://www.wankel-ag.de/entw_e.html
a 4 rotor diesel putting out 260 HP with 130-152 pound dry weight. Again, looks like it just needs some boost.
-Spence
Old Jun 8, 2007 | 01:54 PM
Whizbang's Avatar
Respecognize!
well you can run a diesel engine at 9:1 compression although it will be VERY hard to start and make no power. Then you have to make sure you have the internals prepped in such a way that the globs of carbon dont pile up. Then you try and turbo it to get actual power and run into cooling issues. probably sealing issues too.
Old Jun 8, 2007 | 01:55 PM
moonless's Avatar
I remmber reading about exsperiments with desiel rotories being done early on during the motors infancy. They had problems with apex seals and warped houseings due to the amount of compression a deisel requires to ignite.
Old Jun 8, 2007 | 08:52 PM
WKZ (Works)'s Avatar
American Hashiriya
I think John Deere played around with it a bit before abandoning the project.
Old Jun 8, 2007 | 09:43 PM
4rotores's Avatar
"el father"
there is a company in the uk that is using a four rotor diesel. if i rmenber the sight i will post it.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
