swapping pads between street and track?
Old Jun 5, 2007 | 09:01 PM
coldfire's Avatar
ERTW
When swapping between two different pads for street and track, are there any issues?
do the pads need a bed-in procedure/period every time they are swapped?
thanks,
Aaron
Old Jun 5, 2007 | 09:15 PM
Mahjik's Avatar
Mr. Links
In general, it's recommended to use the same brand for both (i.e. Porterfield for both street and track, or Carbotech for both).
Basically, it's harder for the street compound to scrub off the track transfer layer off the rotor since it's not as abrasive as the track compound. I've never really had any issues, but you could have less than stellar braking for a little bit after switching back to your street compound.
Old Jun 5, 2007 | 09:21 PM
coldfire's Avatar
ERTW
hmm, i'm running EBC green right now on the street. guess i will have to get one of their track pads, whatever that is.
thanks for the tip.
Old Jun 6, 2007 | 02:51 PM
coldfire's Avatar
ERTW
alright so EBC's track pads are the Yellow and Blue. i can't find a part number for the Blue for TII/FD brakes so i'm assuming they don't have them.
is the Yellow stuff a suitable pad for driving schools or a day of lapping?
i'm planning on doing one or two this summer on a fairly big track, but my car isn't that fast so i won't be generating huge speeds or anything. i just don't want brake failure.
edit:
this is what it says on the EBC website
EBC Yellowstuff
EBC’s entry level race material Yellowstuff has slightly lower friction than Greenstuff but with longer lifetime and slightly higher temperature resistance being effective up to over 800 degrees centigrade. The material has been used by many TRD development cars and racers alike, including Martin Bell in his championship winning BMW. Yellow is the choice for that extra percentage of life over and above our Greenstuff and Redstuff range. Yellowstuff is intended for short circuit races of 20 to 30 lap nature, see our Bluestuff for longer races. Yellowstuff is our recommended pad for trackday use.
Old Jun 6, 2007 | 03:23 PM
Mahjik's Avatar
Mr. Links
EBC's seems to be a hit or miss with customers. Some customers really love them, others really hate them. The Yellow's should be fine for your first few events. I would eventually look at something like the Carbotech XP10's or something from Porterfield.
Old Jun 6, 2007 | 03:33 PM
coldfire's Avatar
ERTW
well i've been pretty happy with the Greens on the street/autocross.
and i can get EBC pads fairly easily through a local supplier, unlike something like Porterfield which i would have to somehow get from the states.
guess i might want to think of upgrading my Ford DOT fluid also, ha...
Old Jun 6, 2007 | 03:37 PM
Mahjik's Avatar
Mr. Links
I would recommend Super Blue ATE (and ATE Gold) for brake fluid. Great temperature range and not as hydroscopic as some of the "race only" fluids so you can go farther between completely flushes.
I would also recommend a Power Bleeder: http://www.motiveproducts.com/
Old Jun 6, 2007 | 04:43 PM
coldfire's Avatar
ERTW
yeah i think i will get that brake fluid.
do you know a good online source that sells that fluid?
Old Jun 6, 2007 | 04:58 PM
Mahjik's Avatar
Mr. Links
The link above, Motive Products, sells it.
Old Jun 6, 2007 | 05:16 PM
coldfire's Avatar
ERTW
ah i should have looked further at that site. thanks man, you've been lots of help.
one more thing, do you think i have to get a full set of Yellowstuff? it's pretty pricey for those pads. if i can i would rather just leave the rear Greenstuff on all the time and just swap the front pads.
Old Jun 7, 2007 | 01:34 AM
rynberg's Avatar
If the rear street pads have a high coefficient of friction and you aren't running some modded beast with a lot of track time, running rear street pads should be just fine.
Old Jun 7, 2007 | 07:42 AM
Eggie's Avatar
I agree with rynberg: you're not going to cook the rear brakes. EBC says the Green's Cf is 10% higher than the Yellow's, so you'll get a little more rear bias. This should work well with stock FD brakes.
Old Jun 7, 2007 | 10:24 PM
Black91n/a's Avatar
I change my pads and rotors. You can get rotors for quite cheap (~$100 out the door for all 4) at parts stores like NAPA, and changing them isn't a big deal, so you then don't have to re-bed every time and don't have to suffer the concequences of mixing pads. Hawk pads are the de-facto choice for track driving and are apparently pretty good. I've used the HP+ and then the Porterfield R4, but not the Hawk race pads. For learning the HP+'s are ok, as you won't be getting near the car's capabilities, but when you get better you'll need to get race pads.
I've boiled my rear brakes the last time I was at the track, and that was with fresh 550 degree Ford fluid and the R4's (on unvented rears though). There was also some pad material flaking off the corners. So yes, you can get the rears pretty hot, and that was with street tires (SPT's).
If you're talking about the 550 degree Ford fluid I wouldn't bother "upgrading" it, since some of the "race" fluids actually have a LOWER boiling point. Just make sure it's good and fresh.
diabolical1
30
Jan 30, 2016 05:50 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Engine stand ready
Aug 14, 2015 10:26 PM
ashleymiche
Aug 14, 2015 12:59 PM
