Overboosting issue
Old Jun 2, 2007 | 03:33 PM
NeedFD's Avatar
R. R. R.
Overboosting issue
Ok I did search but I guess i'm just not good at the keywords to use but anyway, here is my problem
I have a single setup, so I'm using an hks standard external wastegate
When I run of the wastegate, it runs normal boost levels (off of the WG spring)
but when I tried to install a boost controller, it tends to overboost.
I tried the Apex boost control kit to my PFC and I've also tried hallman MBC
How is the wastegate supposed to be connected with an MBC? Maybe I installed it incorrectly
on the apex boost control kit, i've connected as follows:
[Intercooler piping] to [NC port of solenoid]
[COM port of solenoid] to [TOP of Wastegate nipple]
[Side of Wastegate nipple] to [Intake manifold]
Also, Is using the top nipple of the wastegate the only way to control boost? Or can I use just the side and piggyback with the MBC?
Old Jun 4, 2007 | 01:39 AM
sirshan's Avatar
Something isnt connected right.
On my car...running a Greddy Profec Spec II
1. From the solenoid, I have a line going in from the Wastegate (side)
2. A vacuum line from my manifold to the "NO" port of the solenoid
Thats all I have hooked up and it works like butter.
rgordon1979
40
Mar 15, 2022 12:04 PM
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
betes
Sep 27, 2015 08:25 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
