Power FC Wiring noise suppressors for PLX and datalogit
Old May 26, 2007 | 09:13 PM
7racer's Avatar
Just a simple question.
with these two suppressors, do I just solder them to the wiring as shown? Do I need to wrap them with shrink wrap to protect them? Obviously a simple question, I just need a bit of an education on this subject.
Thanks.
Attached Thumbnails Wiring noise suppressors for PLX and datalogit-dscf0476.jpg   Wiring noise suppressors for PLX and datalogit-finderscreensnapz001.jpg
Old May 26, 2007 | 11:47 PM
cewrx7r1's Avatar
Eye In The Sky
Two capacitors for two output circuits: (1) 1 V lambda (2) 5 v WB
Only install what you need. Across the +V output and ground.
Of course you have to prevent any shorting out between circuits that are not intended. But how that is done is based upon how you install them.
Old May 27, 2007 | 01:27 AM
7racer's Avatar
Thanks Chuck. I plan on keeping the narrow band and splice it into the input wire to the ECU so I guess that means both. Wait. Hmm...
Do you have any suggestion on how I would install it so I wouldn't short out the system?
I see what you mean now. The only important one is the wideband correct? I really don't need the capacitor or the grey (narrow) wire.
Also, do I just shrink wrap these after they are connected?
Old May 27, 2007 | 08:57 AM
cewrx7r1's Avatar
Eye In The Sky
If you use both outputs, then use both capacitors. It is simple wiring.
You only need insulation if there is the chance of cross connecting to another circuit.
I was doing this when I was about 14 years old, building my first HeathKit.
Old May 27, 2007 | 09:34 PM
7racer's Avatar
Thanks Chuck.
I think I did it right. Or at least I see the gauge working
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
betes
Sep 27, 2015 08:25 AM
The1Sun
Sep 15, 2015 04:45 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
83revival
Sep 3, 2015 10:42 PM
