FD Audio Help: Mystery Pink/Gray/Gray Clip?
Old May 26, 2007 | 03:18 PM
DarkLikePoe's Avatar
It's dark like Poe.
I've searched and found nothing related to this, nor could I find any mention of it on the Bose wiring diagram.
I am trying to replace my stock Bose stack with a single DIN Bose from a 98 Bose-equipped Millenia. The harness clips fit fine, and the deck seems to be getting power. It plays CDs and tunes on the radio, but I get no sound.
I thought my problem was due to the lack of power getting to the Bose amps, so I searched and found that the Bose relay was a PEA GREEN wire. This wire is incorporated into the harness clips. Also, I read that many people have jumped the old CD player clip to restore sound. This is well and good, but of course there is no CD player clip on the new unit; the CD player is integrated already!
I think the problem lies in this TINY (3 wire) clip that I pulled off the Clarion/Bose radio unit. It has two gray wires and one pink one. They seem to be attached on the chassis side to two lines of black primary wire. Are these grounds? Am I colorblind? Is this actually the green wire and I'm on crack? Help!
Old May 27, 2007 | 08:54 PM
It's dark like Poe.
Okay, so here's the wire clip in question. It's the one with, as I said before, two gray wires and a pink one. It snakes up from behind the glove box.
And here's the spot on the OEM radio it connects to. It's the off-white connector in the corner.
Still confused. Please help.
Old May 28, 2007 | 10:37 PM
It's dark like Poe.
Okay, I've been over the Bose wiring diagram and it's REALLY not on there. In fact, there are NO clips that match this one's size. I had thought that someone had swapped in the deck and/or wires, and that perhaps they had used the wrong color wire, but it's not looking like that's the case. Electrical gurus, I humbly request your help! :/
Old May 30, 2007 | 06:47 PM
It's dark like Poe.
No one? Somewhere else I should be posting?
Old Sep 9, 2007 | 10:00 PM
It's dark like Poe.
Just in case anyone else comes looking for this, it was the antenna wiring. The headunit I had purchased was a piece of crap, and THAT'S why there was no power to the amps.
LongDuck
Oct 7, 2015 08:12 PM
BLK 93
11
Sep 9, 2015 10:56 AM
freq
Sep 7, 2015 04:35 PM
