Bosche fuel pump
Old May 25, 2007 | 01:01 PM
93FD3S's Avatar
Big Snail
Bosche fuel pump
So I was skimming through the newest issue of Turbo magazine, specifically the article about the RB26 powered G35. That G35 is insanely sick by the way. Well I noticed they are using a Bosch 365lph fuel pump for their set up. They didn't specify if it was an intank or inline pump. I'm thinking it could possibly be a good replacement. Anyone have any input or info?
http://www.turbomagazine.com/feature...iti_g35_coupe/
Old May 25, 2007 | 01:14 PM
KINETIK_FD3S's Avatar
almost done
you can use it in tank or inline.
Old May 29, 2007 | 12:01 PM
93FD3S's Avatar
Big Snail
Happen to know the Part # and dealer? Looking for a good replacement for my RX7.com pump.
Old May 29, 2007 | 12:16 PM
hondahater's Avatar
spending too much money..
how is your rx7.com pump? What kind of power has that pump supported? Ever think about running a kenne bell boost a pump with it? I've got the same pump and think it's way better than the walbro and could quite possibly support some high hp with a boost a pump. I'm thinking of using this combo with my hbp, t70. Are you looking for a more beefy intake?
Old May 29, 2007 | 12:28 PM
almost done
part # is: 0 580 254 044
i got my pumps from www.boschfuelpumps.com AKA expressfuelpumps.com, if you need 2 pumps they also sell them in pairs from their ebay store at a discounted price.
Old May 29, 2007 | 12:49 PM
hondahater's Avatar
so is that pump a better pump than the rx7.com pump? Here are the differant specs between the rx7.com "new pump" "old pump" and walbro pump.
40psi 50psi 60psi
Walbro 438 405 375 lph
Old RP Pump 490 450 400 lph
New RP Pump 490 475 425 lph
edit: In my last post I ment to say are you looking for a more beefy intank fuel pump. Not intake.
Old May 29, 2007 | 05:36 PM
93FD3S's Avatar
Big Snail
Actually for some reason I thought the RX7.com pump flowed less then 490lph. Hmm guess I'll stick with it for now. I really just want a 1 intank pump set up verse the dual. I'm currently running 850cc and 1680cc secondaries. Looking at 500 rwhp on T04R. Might have to look into the Boost a Pump deal.
Old May 29, 2007 | 05:48 PM
hondahater's Avatar
Yeah I would look into the boost a pump if I where you. You have to remember that it pumps that much at 40psi witch is just about stock pressure. As soon as boost goes up the fp does as well. IF your going to be hitting 20lbs of boost then that is going to up the fp by 20psi so really you will be hitting 400-425lph. I'm not running my setup until I have a boost a pump.
Old May 30, 2007 | 11:05 AM
93FD3S's Avatar
Big Snail
Please let me know when you get your setup running. Thanks man..!!
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
