weak turbo power,sluggish take off
Old Mar 27, 2002 | 01:00 PM
aurdemus's Avatar
Newbie
hello, my friend has an rx7 turbo that he has just bought. it runs fine, but it just doesnt seem to have the umpph on take off that i would expect on a turbo. i used to own a 86, and 87 na seven, and i swear both of those cars pulled better off the line than my friends turbo. all the mags claim 0-60 in approx. 6 sec or so.
it takes his turbo roughly a good 3 sec to kick in, and then its gradual, not a kick in the pants feel. as i accelerate from a stop, it feels sluggish as if im driving a econo 100 hp honda then the turbo kicks in and it speeds up better, but still gradualy.so it is defintaly not doing it in 6 sec. it seems to do fine at hiwayspeeds though.
so , is that a sing that the turbo is starting to go?
or could there be a air leak, or a vacume leak or something easy to fix.
or is that how they are?
could you please also tell me what other sings to look for if the turbo is going out, noises ect.
and other problems that may be the culprit
thanks.
oh yea, it is a 88 or 89 turbo 2 if that helps
Old Mar 27, 2002 | 02:49 PM
Scott 89t2's Avatar
SOLD THE RX-7!
probably cloged cats. how many miles on the engine? compression good?
give it a full tune up too
Old Mar 27, 2002 | 02:57 PM
XLR8's Avatar
Ya, the 89-92's have 200 poneys stock, so it should be dusting the **** of any stock port NA.
Scott89t2 said it best. Gut those cats(don't think you'll hit fuel cut), pull off the turbo inlet duct and check the compressor for movement. get a aftermarket boost gauge and see what your hitting.
Good luck
Old Mar 27, 2002 | 07:57 PM
Jerk_Racer's Avatar
Gut the cats for a quick fix. Do this only if you plan on getting an upgraded exhaust. I went from gutted cats to a full 3" exhaust. It's incredible how poorly the stock setup flows even when unplugged. First get a good aftermarket boost gauge (most brands are good) so you know exactly what you are boosting. A FCD should be the next buy. Gutting the cats won't make the car overboost, but it's good to be safe. Good luck.
jerk_racer@hotmail.com
Old Mar 27, 2002 | 08:21 PM
Chris Ng's Avatar
I'm with stupid -----^
My hunch would be on either clogged cats or stuck, inoperative double throttle plates in the throttle body..
Kyo
Apr 13, 2019 09:24 AM
astrum
24
Nov 15, 2017 08:44 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
