Help: Hesitation at 1/4 to 1/2 Throttle
Old May 22, 2007 | 11:11 PM
Red7spear's Avatar
I just bought my second rx7 its a 87 turbo 2 i runs good at idle and full throttle but when you give it 1/4 to 1/2 throttle it hesitates but if you floor it , it goes fine what could be the problem grounding issue maybe ? or what should i check
Old May 23, 2007 | 07:02 AM
My5ABaby's Avatar
Rotaries confuse me
Sounds like a TPS issue. Test your TPS via the resistance (Ohms) method and look for dead spots. It works best with a multimeter that has a needle as opposed to a digital screen.
Old May 23, 2007 | 07:19 AM
scrip7's Avatar
Rotary Gearhead
5A is right.....the TPS can develop "dead spots" along it's range of operation, also the air flow meter and boost sensor can develop it as well. My boost sensor did and caused a hesitation on accel. I was unable to see the "glitch" with a multimeter but I did see it with my lab scope, which is the best way to test these sensors. Realizing that most people don't have access to a lab scope, your best bet is to backprobe the signal wires from these sensors with a multimeter and hope to find the dead spots. The wiring diagrams in the FSM would be helpful, as well as doing a search in the forum for proper grounding of all components.
Old May 24, 2007 | 12:08 AM
Red7spear's Avatar
I will check the tps and see if thats the case. What sould the tps be set at if it ends up being that and i need to install a new one?
Old May 24, 2007 | 01:49 PM
My5ABaby's Avatar
Rotaries confuse me
1k ohms at idle.
Old May 24, 2007 | 03:32 PM
fcunderwater's Avatar
or if your really rolling in the dough you could get an oscilloscope. That would work better than a DMM.
Old May 24, 2007 | 03:55 PM
-Six-'s Avatar
That's the only thing that would really work well, if you are looking for dead spots. It is pretty tough to get an accurate read just using a mulitmeter, since it is not reading fast enough to give you the same picture an oscilloscope would.
Edit- did some quick google searching and found this PC based oscilloscope: http://www.dynoninstruments.com/common/s2x100.php
I'm assuming one could use a laptop with this thing to diagnose, and it is very affordable ($250) Interesting. Sorry if I am getting off topic.
dona1326cosprings7
Oct 29, 2015 06:47 AM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
lnlreaper
Sep 27, 2015 09:59 AM
