Clever car weight determination
Old May 22, 2007 | 01:50 PM
calculon's Avatar
On flats
LINK
Anyone that knows their car's weight from an actual scale wanna try this and report back for the rest of us in towns that don't have corner scales?
Curious how accurate it could be. . . lots of variables that decrease its validity
It'd be interesting to see.
thanks
ryan
Old May 22, 2007 | 04:14 PM
jgrewe's Avatar
GET OFF MY LAWN
Good for general idea of weight but as you say the variables will kill the accuracy. The biggest being the contact patch isn't a rectangle.
Old May 23, 2007 | 06:23 AM
moremazda's Avatar
Gone Race'n
But if all of the tires are the same size and model you can get a very good approximation on corner weight percentage.
Old May 23, 2007 | 07:13 AM
wrankin's Avatar
Old Rotary Dog
Tires with stiff sidewalls will also throw this calculation off. You also need a very flat smooth surface to do this on.
But as a first order approximation, it's probably not too bad. My gut feeling tells me it's possibly good to +/- 100 lbs or so on each wheel. If I get the chance I'll try and remember to try this out on the FC (which is corner balanced and I do know the weights).
The engineer in me cringes when he sees them carrying their calculations out to seven significant digits - implying accuracy where there is none.
-bill
Old May 23, 2007 | 10:58 AM
j9fd3s's Avatar
Community Builder
this is prolly good if you've already built the car, and are just setting it up....
Old May 23, 2007 | 05:27 PM
scotty305's Avatar
~17 MPG
They said "if you get within 10% of the weight stated in your owner's manual, good job!"
10 percent on my car would be about 279 lbs; I don't think any of us would be satisfied with the results. I've measured corner weights on a set of racing scales, so maybe I'll try this just for kicks.
-s-
Old May 24, 2007 | 08:45 PM
NeoTuri's Avatar
The shy megalomaniac
I just tried one of the tires, and yes, the contact patch is not a rectangle.
I had a feeling my calcs were going to be off as I could see how much surface area fit inside of the "rectangle" but didn't touch the tire.
My car weighs about 2700lb, and I got 1000 lbs on one corner using the calc.
cristoDathird
28
May 30, 2019 08:47 PM
astrum
24
Nov 15, 2017 08:44 AM
