Spring rate suggestions
Old May 21, 2007 | 01:37 PM
Bunchies's Avatar
I have a set of coilovers that I am having built at ground control. I need to pick the front and rear spring rates. My choices for the front are: 350, 375, 400 and the rear can go 340, 380, 440.
I was thinking of a 400F/340R rate. Currently, it's at 375F/250R.
Old May 21, 2007 | 02:24 PM
aznpoopy's Avatar
strike up the paean
400/340 would be my choice out of those rates.
anything else has the front rear rates very close to each other, or the rear higher than the front... seems like a recipe for a tail happy car, all other things being equal.
Old May 21, 2007 | 02:39 PM
Bunchies's Avatar
yeah, i just figured that if it turned too tail happy at 400/340 then i could just remove the rear sway bar.
Old May 21, 2007 | 09:28 PM
Pat McGroin's Avatar
Sushi ******!
I have 385 front and 300 rears. I got the softest rates for the size springs I ordered, once I track the car and learn it, then I'll play around with springrates if need be.
Old May 21, 2007 | 10:06 PM
Bunchies's Avatar
Just remembered that the rears are stock valved koni yellows. Is it safe to move up to a 340lb spring on those shocks?
Old May 22, 2007 | 07:08 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
400-340 should work nicely w a dual purpose street/track function. just remember to run 2 to 3 psi less in the rear. your konis will work fine...
25 inch ride height front and rear.
good luck,
howard coleman
Old May 22, 2007 | 09:27 AM
ptrhahn's Avatar
Honestly, not to argue with Howard, but I'd go higher w/ Konis... it'll actually HELP your ride quality. When I had Eibach pro-kits, with are about 365/285 (IIRC), the thing was always crashing down over bumps and such. My GC's are 500/400 and it's actually much better, particularly if you're going to run as low as 25" like I do and Howard suggests.
You'll find that the shock valving has more to do with ride quality than spring rate (within reason) anyway.
Old May 22, 2007 | 11:37 AM
Bunchies's Avatar
yeah, i think i'm going 400/340 and running the rears at full stiff (dyno matched of course)
Old May 22, 2007 | 02:11 PM
Nathan Kwok's Avatar
FWIW I'm running this setup with 450F/350R, 25" ride height, and I'm pretty happy with it.
Old May 23, 2007 | 01:35 AM
maxcooper's Avatar
WWFSMD
SA/FB or FC or FD, what car are these for? Looks like an FC in your pic, but I think you are getting "FD advice".
-Max
Old May 23, 2007 | 11:35 AM
Bunchies's Avatar
-Max
Woops, sorry, i never specified. It's an FC. Pretty much, the information that I've gathered from multiple forums states that the konis should hold up with a bit of compensation on the damping setting at 340lb. The fronts will be going with 380-400.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Ernstudet22
Sep 14, 2015 09:19 PM
