Sponsored by: CARiD
Automatic FD question
Old May 18, 2007 | 12:06 PM
RotaryNemesis24's Avatar
I test drove an auto FD yesterday....Was kind of shocked that when i hit the gas....it barely went anywhere....very little throttle response. Is it normal to not have any power till the turbo's kick in?
Old May 18, 2007 | 10:57 PM
SchoolZone's Avatar
Non-Transferable
the primary turbo does not have much lag so you should feel something.
Old May 19, 2007 | 01:49 AM
RotaryResurrection's Avatar
From idle to 2.5-3krpm the car will be slow as a ford escort. From 3k to the shift, and from there on out provided the boost pattern is correct and you do not let out, it should be pretty quick.
I found a dyno sheet of a pretty stock automatic FD a few days ago and I believe it put down around 235 at the wheels (I believe it was running 12psi instead of 10), which is common mildly modified FC t2 territory, so it's not all that fast, but quick and fun. I've driven several and they are not bad, but a rearend gear change and a 3000+ stall would make them a BEAST from light to light.
Old May 19, 2007 | 01:59 PM
weaklink's Avatar
Resident Retard
stock stall IS 3K.
Old May 19, 2007 | 04:24 PM
On paper perhaps, but in reality when you brake boost or floor the throttle the stall is in the low to mid 2000rpm range.
_Tones_
May 25, 2021 05:37 AM
jakeishness
11
Sep 11, 2015 11:33 AM
Nosferatu
Sep 5, 2015 02:13 PM
