New engine and setup doesn't start?!
Old May 15, 2007 | 02:06 PM
iikori's Avatar
I'm not a professional in wankel engines. so... can anybody say any helps to my problem.
I have new ported engine, Apex'i Power FC, Garret GT40 turbo, 550 primary injectors, 1200 "bosch" secondary injectors and so on, but the new engine won't start. Fuel smells very much when starting and there is new plugs in the engine and those works. I think there is somekind of problem in timing.. any ideas how to fix??
Old May 15, 2007 | 03:24 PM
PhatManBUD's Avatar
might be flooded.
What does it do when you crank it? any noises etc. you can describe to let us help guess your problem
Old May 15, 2007 | 08:31 PM
cewrx7r1's Avatar
Eye In The Sky
That injector setup is only good for about 370whp. It is not suitable for your port and turbo combination unless you will be running low boost. At which casedoes not make sense for having a GT40.
Old May 15, 2007 | 11:59 PM
iikori's Avatar
there is nothing special sounds when you crank it. What that flooding means actually? Can I try to start with pulling?
Old May 16, 2007 | 05:57 PM
iikori's Avatar
Today the car starts first time with pulling... better than anything. But when you try to start it with key.. nothing happens.. weird.. mayby too much fuel, but why.
Kyo
Apr 13, 2019 09:24 AM
PhillyFC
Aug 21, 2015 06:36 PM
smikels
Aug 18, 2015 01:26 PM
