compression test w/ engine pulled?
Old Mar 26, 2002 | 11:41 AM
rxspd's Avatar
Hey, can i compression test my engine with it out of the car? how do i do this? can i use a standard tester?
Old Mar 26, 2002 | 12:24 PM
rxspd's Avatar
bump
Old Mar 26, 2002 | 12:29 PM
jimmyv13's Avatar
Round&Round not Up&Down
Sure. Get power to the starter and take the Shrader valve out of the tester.
Old Mar 26, 2002 | 12:47 PM
bdc196's Avatar
You can, but the rule of thumb that I stick to is this: try and test each chamber's compression when the engine is at operating temperature. This way, you'll get a more proper reading as all of the metals of the engine (and engine pieces) are nice and properly seated. If the engine's already out, that might be hard to do unless you fashion a test stand and let it sit and run.
B
Old Mar 26, 2002 | 01:23 PM
buttlips's Avatar
How much compression should a series 4 n/a engine have?
Thanks
Old Mar 26, 2002 | 01:28 PM
selanne8's Avatar
why can't you just hook up the compression guage and crank the engine by the flywheel? i don't see why you need the starter to do it, unless it's a matter of strength.
Old Mar 26, 2002 | 03:47 PM
hypntyz7's Avatar
You cant turn the engine by hand fast enough to get a reading. You can feel for pulses by hand form each plug hole and count to 6 alternating.
I use a tranny and starter and battery on the floor, and do it that way.
LunchboxSA22
37
Oct 26, 2015 10:53 AM
elfking
Aug 19, 2015 09:48 PM
