possible turbo problem?
Old May 14, 2007 | 04:09 AM
WadeMCarter's Avatar
i was swapping my LIM gaket (pita for me), and in the process i think i might have done something to the turbo. even thought i was pretty consistant with blocking off the inlets of the manifolds and turbo, the removal of the turbo was pretty sketchy and sloppily done by myself. it sort of banged up against some things while putting up a fight, and after reinstallation of everything, i started the car and in the uper 2000s/lower 3000s, there was this whining noise that sounded like a supercharger or a belt that was loose.. i am trying to be more mechanically inclined, instead of just book smart, but its experiences like this that make me not be too confident. please tell me i didnt ruin my turbo
Old May 14, 2007 | 08:52 AM
Aaron Cake's Avatar
Engine, Not Motor
It would be hard to damage the turbo by banging it around.
Did you separate the turbine or compressor housing?
Noise could just be a vacuum leak, or a slipping belt...
Old May 14, 2007 | 10:57 PM
no i didnt seperate them. the belt seemed tight and snug.. vac leak is probably it. thank you!!!
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
