rx7 shut off while driving, wont start
Old May 14, 2007 | 02:12 AM
redline_13000's Avatar
Bogged out while driving, turned it on again, it revved up to about 2500 rpm then shut off, wont start anymore. The car has a fuel cut off switch, no luck using that, also pulled the fuse, still no luck. Any suggestions on what the problem could be? And yes it does have about half a tank of gas.
Old May 14, 2007 | 09:37 AM
RRTEC's Avatar
Rotartist
Clogged fuel filter?
MAF came unplugged?
Huge Vac leak?
What model is your car? Turbo? N/A, Year? Help us help you.
Old May 14, 2007 | 11:28 AM
TweakGames's Avatar
FD pro licensed driver
Mine did the same thing the other day. It was running on 1 rotor for a while. I think one of the injectors got stuck open, or one of the sparks wasnt firing for a sec and caused one of the rotors to become VERY VERY flooded. I had to take the spark plugs out, and mess with the injectors. A few hours later it worked fine, both rotors worked and I drove 1000 miles the next day with no issues. *Shrug*
Im not saying thats your problem, but that's what happened to me.
Old May 14, 2007 | 01:33 PM
N/A 88 convertible, i was thinking of pulling the spark plugs but the car was driving fine then shut off, It wasn't sitting and shut off for it to flood
Old May 14, 2007 | 01:36 PM
iSP33D-for-J3SUS's Avatar
s4 Tails for Life!
Talking
One day while driving a vac hose blew off on my car. It wouldn't idle. Check all your hoses. I found the hose on mine and zip tied that sucker up!
Cheers,
Cody
Old May 14, 2007 | 02:26 PM
stevej88na's Avatar
Strength and Honor
Cheers,
Cody
I second this - for me it was a large hose on the bottom of the intake pipe after the AFM.
Old May 14, 2007 | 03:33 PM
Gregg Grimm's Avatar
Rottweiler kibble
ok question on same line. mine sat all winter so i changed fluids and stuff now it wont start it rotates but i get no catch i tried the fuse thing but no luck please help me out
86' 13B (no turbo yet sadly)
Old May 14, 2007 | 05:02 PM
I had an alternator belt snap while driving one day and the car immediately died. Took me hours to figure out what happened. Turns out, the snapping belt SHEARED off all of my CAS wires underneath the electircal tape... so from the naked eye it looked like they were all still attatched..
silly stuff happens sometimes. I doubt its a blown motor. Check compression anyways, then check for fuel and spark. Post your updates
immanuel__7
89
Sep 5, 2015 10:23 AM
PhillyFC
Aug 21, 2015 06:36 PM
ashleymiche
Aug 14, 2015 12:59 PM
