Air pump ???
Old Mar 26, 2002 | 07:49 AM
to_slow's Avatar
Question Air pump ???
What do you guys do with the holes from the air pump after removing it ? Plug them up both or just the one in the engine bay ?
Thanks
Old Mar 26, 2002 | 09:09 AM
rxrotary2_7's Avatar
please refer to this thread. the part about searching would apply. https://www.rx7club.com/forum/showth...threadid=65073
AFTER you read that. Then...and ONLY then should you check out this link. i did all the hard work for you of typing in those magical words "air pump"
https://www.rx7club.com/forum/search...by=&sortorder=
Old Mar 26, 2002 | 09:10 AM
sorry to be so harsh, i just dont understand what is so hard about searching.
Old Mar 26, 2002 | 09:16 AM
RecKleSs's Avatar
Adrenaline
I had mine off for a little while and I'm in Florida right now, so I can't look under the hood for you at this moment. However, there are two black hoses that are right behind the Y-Pipe. You would have to cover it up with a rubber piece and use a clamp to make sure it doesn't comes off. Basically, you just have to plug both of them up.
Old Mar 26, 2002 | 09:36 AM
to_slow's Avatar
Well you are right do the search ,but when i do the search and come up with nothing .What then? If you do read all them post on air pump there is not one that it can help me out . Thanks
Old Mar 26, 2002 | 10:11 AM
you may not get EVERY thread with your exact question, but by sifting through the searh results, you should get what you are looking for. here are a few i pulled up for you.
https://www.rx7club.com/forum/showth...light=air+pump
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
