RX7 project "Penny", stage 1, link, Q & Comment thread.
Old May 12, 2007 | 11:46 AM
NoviceRotaryTech.'s Avatar
Home-brew Rotary
Here's a link to the main thread.
forum.teamfc3s.org/showthread.php?t=54236
Well I guessed that the flooding issue was from leaking injectors.
After taking off the LIM I checked out the lower injectors (secondary's, right?).
I sprayed a little brake cleaner in them, then tapped and blew them out.
Well weather or not its right to clean them that way, I think I found one of the leaking injectors, cause when I blew through one injector the liquid was coming slowly out the other end. I don't think it should do that.
Still need to check the upper injectors.
Also, one of the 5th&6th port sleeves is stuck in the port, I got pliers and tryed to turn and pull on it but it woulden't budge.
Any ideas how to remove it with out destroying it?
_________________
'87 Mazda RX-7 (gxl)
Current project. "Penny." Details Now.
Old May 20, 2007 | 09:32 PM
Home-brew Rotary
The link has an update.
Stage 2 to come.
Old May 23, 2007 | 05:12 PM
Home-brew Rotary
The link has been updated with Pictures.
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
