Pettit Rear Fender Flares - Install notes and pics.
Old May 12, 2007 | 05:39 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
So I installed the pettit rear flender flares to be able to run the 12.5 CCWs rims and 335 wide tires.
Here are my install notes and pics:
First you should do a test fitting to make sure they line up well and mark off where the mounting holes need to go, et. I had to trim some material off the very bottom/inside edges of the flares to get them to seat right on the body. I am talking about the inside ot the 2 bottom corners, that go in towards the center of the car.
Then what I did was mark about 2 inches up from bottom edge of the fender and draw a smooth curve down the the sides like the mark shown below:
It helps to cut off just the bent lip of the fender, like you see in the pic above. I used a nice sawsall that my buddy Bruce let me use.
Also in the pic above, you can see the hardware I used to fasten the flares to the body are called 'rivet nuts'. They allow be to bolt the flares on/off relativly easily. they are kinda a pain to get mounted in body, but work out very well.
Ok, now I cut from the edge of the fender up to the line i made, with about 2" spaces beween cuts. It ends up looking like flower pedals. Then I bent the outer fender shell pedals to the out sideadn then grabbed the inner layer fender pedals and bend those to the outside, so that they layered on each other a bit, forming almost a new fender liner shape. You can see what I mean in the 2 pics below.
After that is done I test mounted the fenders again and made sure that the metal 'pedals' didnt hit the fenders in a way that would keep them from sitting on the car well. Here is a pic of how they ended up looking with the new fender flare on:
And here is a pic of the sheet metal fender liner I added to cover the slots made from the cuts. Also, be sure to paint up any open metal edges to keep it from rusting.
I posted many pics of the final results in this thread:
https://www.rx7club.com/forum/showth...ht=damian+wide
Old May 12, 2007 | 06:57 AM
rx slim's Avatar
Very nice! Looks like one fun car to drive!
Old May 12, 2007 | 08:11 AM
cabaynes's Avatar
Old and grumpy
Looks good Damian, but there is no way I would ever take a sawsall to my car... You're braver than I!
Old May 12, 2007 | 08:19 AM
allrotor93's Avatar
i think the huge question everyone has but pettit cants answer. what sizes/offsets can we use?
Old May 12, 2007 | 10:08 AM
Zero R's Avatar
Just in time to die
I had to go through the same thing this winter when widening my car. The only thing I did different was weld the seam back up to keep some rigidity between panles since I'm doing a bit different setup. Isn't it funny just how much better the car looks with 315 to 345's under it I'm just now going through the wonderful pains of putting a cage in my car, fun stuff.....
-S-
Old May 12, 2007 | 11:12 AM
HKNY's Avatar
Thou Shall Search
looks good
Old May 12, 2007 | 01:23 PM
vel525's Avatar
Woo Hoo, It Runs!!
-S-
Sean,
Glad to hear you're making a little progress on your car
Any progress pics?
Victor
Old May 12, 2007 | 01:37 PM
RE-Amemiya's Avatar
Not the company
Nice writeup again Damian! Still think you have one of the most bad-*** cars on this site.
Any word on when some new vids might be up!?
Victor: How about some progress pics of your car!
Old May 12, 2007 | 01:49 PM
FD3S2005's Avatar
SideWayZ The Only Way
looks like the right rear fender next to the tail light and a little of the bumper is damaged
Old May 12, 2007 | 02:02 PM
Zero R's Avatar
Just in time to die
Originally Posted by vel525
Sean,
Any progress pics?
Victor
Yeah I'll post up some stuff just not sure what section yet, also I wont put my pics in damian's thread.
-S-
Old May 13, 2007 | 01:30 AM
DomFD3S's Avatar
Mod Powers...gone!
Thanks for posting this. Excellent info.
Old May 13, 2007 | 07:28 AM
wptrx7's Avatar
Newb Photog
What offsets are you using?
Old May 13, 2007 | 08:51 AM
RISEN's Avatar
In my opinion, the Pettit fender flares ruins the smooth lines of the RX-7, unless you do a lot more body work to smoothen it out like the Camo/Endless RX-7.
Old May 13, 2007 | 10:46 AM
bikojohn's Avatar
thanks
I looked at all the post about this in the past. It is good to see how people do it. one more time thanks!!!
Old May 13, 2007 | 11:28 AM
Mr3plus1's Avatar
Mostly stock
Did you cut the underside of yours like that? I know I left a much smaller lip than you, but that was to keep it looking as stock as possible. I also molded mine in and filled in that extra gap between the flare and body with a layer of fiberglass.
On a side note here's how I did mine....
I first cut out about one inch from the wheel well so I could remove the lip. Then I progressively hammered (a LOT) and made cuts where I needed to in order to flatten out the inside roof of the wheel well. I welded it all back together....
All that bare metal got covered with rhinoliner to prevent anything from rusting if it got caught inside the flare. It also helped seal up any small air holes left from welding. Here's what it looked like with the original chopped off piece wedged into its original position.
Here's the inside of my wheel well....
Not to hijack your thread. For anyone reading this, take into consideration Damian rivited his on and Im molding mine in. His is a lot more practical whereas mine is just for looking cool.
Good job man. Ive always loved your car. Im curious on the offset aswell. I could probably call Pettit up, but I hate talkin to that guy. He just talks my ear off.
Old May 14, 2007 | 03:47 PM
vel525's Avatar
Woo Hoo, It Runs!!
My wife is out of the country with the camera
But I think I might head up to check on the car Friday.
BTW (just so I'm somewhat on topic) - Damian, the car looks great!
Old May 14, 2007 | 09:43 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
I would not do it to my street FD:
Just the track FD:
But the track car is anotehr story :-)
Old May 14, 2007 | 09:49 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Well, I run 18x10 (285/30 tires) with 7inch backspacing in front
and 18x12.5 (335/30 tires) with 7inch backspacing in the rear
Call John at CCW, he knows the numbers :-)
The backspacing for the rear rim stays the same as an 18x10 with normal fenders, since you can not go in any further or you will hit syspension parts, so the added 2.5 inches just going outward, keeping the same rim offset.
Old May 14, 2007 | 10:18 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
uhhh, its a race car :-)
that is from a spin in the rain i took at RoadAmerica in the one lap of america, out of turn 13...ther rear kissed the wall.... front took a nice tag there too :-)
Old May 15, 2007 | 01:01 AM
RISEN's Avatar
Old May 15, 2007 | 03:33 AM
DS2000's Avatar
Rotary Monkey
Wow, lovely FD
Old May 15, 2007 | 02:19 PM
NoDrySkin's Avatar
I want that ***.
Old May 29, 2007 | 08:01 AM
ARMAN's Avatar
WOTCOP
mean!!!
MILOS7
Aug 19, 2015 07:25 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
