cooling mist kit
Old May 12, 2007 | 01:07 AM
JABrx7's Avatar
cooling mist kit
I jest picked up a dual stage cooling mist kit for my turbo. Here are some pics of it
Old May 12, 2007 | 01:17 AM
drift_the_fc's Avatar
what does it do??
Old May 12, 2007 | 01:20 AM
JABrx7's Avatar
it cools the intake charge.
Old May 12, 2007 | 01:24 AM
how much more horse power does it give you?
Old May 12, 2007 | 01:28 AM
84stock's Avatar
"It" doesn't give any more power, what it does do is give the installer the "capability" to tune for more power by adjusting fuel and timing curves. Using a 50/50 water/methanol mix you increase ocatane to over 100 and permit more timing, cool intact charge and permit more boost.
JABrx7's Avatar
ya what he said^^
Old May 12, 2007 | 01:38 AM
thank
Old May 12, 2007 | 03:26 AM
HeyITZthatFC's Avatar
fc3s
any cons to that?
Old May 12, 2007 | 03:48 AM
86gxl_fc's Avatar
wow, how much did that kit cost you?
i've been thinking of installing something like that.
i would prefer getting this as oppose to the ever so popular
"Cold Air Intake"
but methanol? is methanol really necessary. i mean wouldnt play water be suffice?
Old May 12, 2007 | 12:56 PM
JABrx7's Avatar
i got it for $175 from a friend of mine who got it but then changed his mind and went to alk injection.
Old May 12, 2007 | 01:03 PM
Alex6969's Avatar
The Silver Bullet
I looks like its the newer model that uses Nesquick, the 87 version.
Old May 12, 2007 | 01:26 PM
JABrx7's Avatar
lol didnt you hear that nesquick give you like 20 hp.
Old May 12, 2007 | 01:31 PM
w33n's Avatar
Geriatric lurker
I was actually looking into a direct port Nesquik system.
I heard they tend to lock the engine though. Something about running pure sugar tends to hurt your apex seals...
I think it's just a bunch of skeptics.
^_^
Old May 12, 2007 | 01:40 PM
JABrx7's Avatar
ya but they fixed that on 85 kit all you do is add some milk and watch as you hit low 10's lol.
Old May 13, 2007 | 01:24 PM
dean23's Avatar
pwned
^^HAHAHAHA
whats the brand name of the system? im gonna be needing one of these soon, well that or alky inj. but i dont want to mess with that yet..
Old May 13, 2007 | 01:29 PM
jamespond24's Avatar
Nice buy!
Old May 13, 2007 | 01:49 PM
rogrx7's Avatar
Turbovert done.
Hope no one turns on the stove
Old May 13, 2007 | 03:02 PM
J-Rat's Avatar
Alcohol Fueled!
There ya go. I have been running achy for YEARS, and I love the stuff!
Old May 13, 2007 | 03:34 PM
Digi7ech's Avatar
I break Diff mounts
What are your supporting mods?
EMS or Stock ECU?
I've been debating wether an injection system on a stock ecu will work or not.
I think Chemical intercooling is the only reliable method in hot places like AZ.
Old May 13, 2007 | 03:38 PM
marcus219's Avatar
FC Mobsta
why can't you just run alcohol through that kit?
Old May 13, 2007 | 06:59 PM
MrFuzzy's Avatar
Damn Right It's Me
Would probably eat the hoses
Old May 13, 2007 | 07:21 PM
JABrx7's Avatar
its a cooling mist kit and as for mods i have a s4 street ported motor with an s5 bnr stage 2 turbo. at some point i will probably get rc 750 secondaries and a walbro 255 pump.
Old May 13, 2007 | 08:42 PM
Digi7ech's Avatar
I break Diff mounts
What about ECU though?
How are you going to compensate for the water?
EMS with a tuned map for it?
Or Stock ECU with the injection far ewnough up stream so the stock sensors see the change?
Old May 13, 2007 | 09:00 PM
JABrx7's Avatar
well the guy i talked to said i didnt need any turning with it since its only spraying a fine mist of water and all it really will be doing is cooling the intake charge.
Old May 13, 2007 | 09:51 PM
Digi7ech's Avatar
I break Diff mounts
You will be substituting a little air with water and the intake temp drop needs to be measured or else the ECU will do incorrect math.
I've thoguht about doing it on the end tank of the top mount but wondered if pooling would be an issue or if that was enough distance for the temp change to be recorded by the stock air sensor.
Pre intercooled injection isn't liked because the IC itself could condense the water on the fins.
If you had a front mount then I owudl say there would be enough piping distance to properly disperse the water and drop the temp before it reaches the sensor.
