blowing EGI fuses?
Old May 12, 2007 | 12:28 AM
re-rx7's Avatar
Vp in charge of Girls
blowing EGI fuses?
My car has started blowing Egi fuses i believe this controls the ignition??? Anywayz car has ben having rough idle problems and plugs are black plus iam running pre-mix. N E suggestions?
Old May 12, 2007 | 05:36 AM
R-1's Avatar
R-1
had customer with same problem
try checking the water thermosensor if it broke from cahnging the alternator and it is grounding that will blow the EGI fuses. most people forget to put a 17 wrench on the back when removing the alternator and this will brake the sensor
FC3S Timmy
16
Oct 3, 2015 01:08 AM
