stopping from 150mph+...
Old May 7, 2007 | 09:40 AM
Rotor Nut.
having some trouble bringing my car down from high speeds. yesterday i took the car for a nice highway run and there was a good stretch of road ahead so i put the pedal down for a bit got up to 150-155mph, when i started comming closer to the other cars i went ahead and applied the brakes. well by around 110mph it really didnt want to slow down any more. you could also hear the hum comming from the rotors. the wheels was fairly steady. on the other hand now, i was in my buddies evo and it stopped from 150mph like i was stopping from 75mph. im running hawk pads, stock rotor size and calipers, also stock brake lines. do i need better pads or is it time for a brake upgrade?
Old May 7, 2007 | 09:47 AM
Mahjik's Avatar
Mr. Links
If you are just looking for more bite for braking, yes better pads will do it. I've said it before, and I'll keep saying it: Hawk pads suck *ss...
Old May 7, 2007 | 09:52 AM
Rotor Nut.
i would just like it to continue stopping, it seemed as if the pads didnt want to hold the heat. which pads do you recommed?
Old May 7, 2007 | 10:00 AM
Mahjik's Avatar
Mr. Links
Depends on your budget. I like the Carbotech Pads. The Bobcats are a good street pad. Their old Panther+ now called AX6 is good for aggressive driving and AutoX, but still not a true track pad (should you ever do a lapping day).
I've had good luck on the streets with Bonez Stage I pads from RX7.com. Also, Porterfield R4-S.
Old May 7, 2007 | 10:19 AM
rynberg's Avatar
Well, I'm not a fan of Hawk pads either but you have a mechanical problem of some sort to experience this. You don't need to "upgrade", you need to fix the problem. (Mechanical problem could be as simple as glazed over pads....)
Old May 7, 2007 | 10:20 AM
Rotor Nut.
i dont mind spending some to help the car stop. here is how i drive the car. weekends only, mostly normal, occasional 140mph+ pull on the highway. i just want them to stop from high speeds and not fade off the way it did. btw where can i find the carbotech pads? i did a quick search and they were only comming up for the dsm's.
Old May 7, 2007 | 10:25 AM
Mahjik's Avatar
Mr. Links
I personally would take this time to "freshen", not necessarily upgrade, your braking system. I would go ahead and change out your brake lines (whether that's SS lines or new stock rubber lines), flush your brake fluid and use something more "robust" for that type of driving like ATE (Blue & Gold), and add in some better pads.
I wouldn't necessarily replace the rotors without examining them. Check for wear and see if they need to be replaced or not.
Old May 7, 2007 | 10:28 AM
Mahjik's Avatar
Mr. Links
You can buy them from a few places. I get them from these guys: http://www.dpeweb.com/
They will be delivering the Carbotech XP8 pads for my M3 this week.
Old May 7, 2007 | 10:34 AM
Rotor Nut.
rynburg, any suggestions? i also figured it didnt seem right. what does it mean when the pads are glazed over? also how can i get rid of it. when i first installed the pads and rotors i did the bedding correctly. also why does it hum stopping from high speeds?
Old May 7, 2007 | 10:10 PM
maxcooper's Avatar
WWFSMD
Hawk HPS pads are fairly easy to fade. I remember fading them with a single 130MPH stop. Try some different pads.
-Max
Old May 8, 2007 | 01:40 AM
rynberg's Avatar
I would look at the Axxiss Ultimates also, those are really good aggressive street pads. Also, what tires are you running?
Old May 9, 2007 | 04:36 PM
Tanj!'s Avatar
I'd also look into EBC Red or Yellow. The red's are marketed as their aggressive street pad. They can be a bit aggressive to the rotor material and will cause some grooving to the rotor. Personally I prefer the Yellow over the Red. The yellow is marketed as their race pad however it is perfectly acceptable to use on the street. It actually has better stopping power cold than the red does and only improves as they come to temperature according to EBC's own literature. It's a very rotor friendly compound and will not eat rotors.w
Old May 10, 2007 | 03:16 AM
Black7Conv's Avatar
I am using EBC red and green..they are excellent, nice stopping power when I need it..
Old May 10, 2007 | 07:34 PM
Given your rwhp, this wouldn't be a bad idea
https://www.rx7club.com/suspension-wheels-tires-brakes-20/fd-new-brake-options-605463/
Old May 10, 2007 | 07:59 PM
Mahjik's Avatar
Mr. Links
https://www.rx7club.com/showthread.php?t=605463
I beg the differ. If he was actually running on a track rather than highway runs, maybe.
Old May 10, 2007 | 11:01 PM
My tongue was partially in cheek....he did say he wouldn't mind spending some to help the car stop
Old May 11, 2007 | 09:59 AM
Rotor Nut.
ill give a new set of pads a try, if that doesnt work a set of stoptech's or racingbrake will be going in.
also rynberg i have potenza re750's on my 18's
LongDuck
Oct 7, 2015 08:12 PM
Rotafuzz
Sep 30, 2015 09:55 AM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
dexter snoek
Sep 29, 2015 09:18 AM
