Air Thermosensor Help!
Old May 4, 2007 | 03:13 PM
gio64's Avatar
Hi everyone.
I get a code and I did what is written here, it is code 11, air thermosensor.
I live in Hamilton, Canada. I found the part # here and went to the dealership with it.
I ordered, picked it up and paid.
Two problems:
1) on the little box that contains the sensor, there is the part # stamped right under the following writing: Temperature Sensor Water.
Any ideas?
2) I read here that somebody has removed the faulty sensor and installed the new one without removing the UIM. Now, I am not really in the mood to disconnect the 4000 things attached to the UIM (I'm afraid something is going to go wrong), so I'd like to do it without removal. I took a look at the situation and I cannot see anybody but a Martian to be able to remove this thing without taking the UIM out. It's not just the fact that it's hard to get to it with a wrench, I can find something that would work; it is rather the fact that there is another sensor in the way and I cannot see any tab on the plug that I could possibly depress to then pull the connector out.
Any images/ideas/help/moral support?
Please, I understand that the removal of the UIM would make this very easy. But I don't think I can handle this properly and I would also need a new gasket, which I don't have at this time.
Thank you in advance,
Giovanni
Old May 4, 2007 | 04:53 PM
Sgtblue's Avatar
Urban Combat Vet
As for the box your thermosensor came in, mine did too, and it was ordered directly from Ray at Malloy Mazda. I have no explanation but the PN# should be N3A1-18-845.
As for changing out the sensor without removing the UIM, I don't think it can be done. You may be able to find a thread where someone has bent an old wrench and been able to do it, but that also sounds like more trouble than it's worth. Gasket's are only about $8 -$12 IIRC.
Old May 4, 2007 | 05:16 PM
dontlift's Avatar
Blithering Idiot
Air and water temperature sensors (gauges also) are generally interchangeable. Mazda probably used the same part for both sensors on the FD...
FlatVermin
22
Sep 27, 2015 05:42 AM
