Megasquirt Quick/Stupid Ground Question
Old May 4, 2007 | 02:03 PM
pitchblack7's Avatar
Does it matter where I ground pins 8, 9, 10, 11, and 19 to? Right now I have:
pin 9 grounded to harness wire 2R
pin 10 grounded to harness wire 3A
pin 11 grounded to harness wire 3G
pin 19 grounded to harness wire 2C
I still need to ground pin 8 and I wasn't sure if its ok for it to share the same ground with another pin. Thanks.
-Andrew
Old May 4, 2007 | 02:06 PM
muythaibxr's Avatar
MegaSquirt Mod
Pin 19 should be grounded to one of the "2" grounds... whichever one is the sensor ground.. which can be checked by using an ohm meter to check for continuity from that pin to one of the MAT sensor plug's pins.
I can't remember off the top of my head which one it is.
Old May 5, 2007 | 10:11 AM
Alright, thanks. Do you know where pin 8 needs to get its ground from? Thanks.
-Andrew
rgordon1979
40
Mar 15, 2022 12:04 PM
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
