Car Chemistry header inserts...
Old Mar 25, 2002 | 11:25 AM
Cheuk in Seoul's Avatar
Anybody try these things.
www.carchemistry.com/ccinserts.html
Sounds like the exact thing I am looking for. I thought maybe I could put one into my cat back or weld it into the back portion of my midpipe. Who cares about hp losses... I have a midpipe cut out welded in for the track.
Anything for a little noise reduction and its cheaper than a new exhaust.
I am ordering mine today from Summit... we'll see how they work.
Cheuk
Old Mar 25, 2002 | 12:30 PM
CYM TKT's Avatar
hey, your car is on fire!
when I had mine it did not just "slide in"... there was some modification required. it makes it sound kinda nice (definetly quieter), but you wont get flames anymore.
Old Mar 25, 2002 | 01:42 PM
Pressurized's Avatar
I have a 3-ring in right now(well it was, I cut 2 rings off) and mine fit rather tight with no modifications, pounded it in there with a hammer but it's still loose enough to pry out with a crow bar. I use it to control boost creep and it does a good job, as for the 'muffling' it's not too bad. I have a Pettit resonated along with this and it's pretty quiet at idle and cruise, but it still gets pretty damn loud at WOT, but the noise stays outside of the car.
Old Mar 25, 2002 | 01:43 PM
I have a 3-ring in right now(well it was, I cut 2 rings off) and mine fit rather tight with no modifications, pounded it in there with a hammer but it's still loose enough to pry out with a crow bar. I use it to control boost creep and it does a good job, as for the 'muffling' it's not too bad. I have a Pettit resonated MP along with this and it's pretty quiet at idle and cruise, but it still gets pretty damn loud at WOT, but the noise stays outside of the car.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
