Megasquirt P&H Driver Board
Old May 2, 2007 | 05:02 PM
T2GTUS's Avatar
Cool P&H Driver Board
I wanted to give the P&H board from Jean Belanger a try ...
P&H Board Thread
I ordered some up and got 1 done recently ... It is a tight fit w/ the error board ... but they do barely both fit on the upper-most slot ...
I think I'm the guinea pig but, has anyone else here tried it out ... and if so ... did you try it with hi-res and what were your thoughts ...
Old May 2, 2007 | 11:00 PM
The Griffin's Avatar
Burning up Time
Doesn't look like you have the P&H board wired yet,correct? Is that all going to fit once you add the injector wiring for the P&H board ?The wires are thick for the injectors and the one pic I seen of that board had only 2 of the 4 injector circuits wired and it looked like it took up quit a bit of space inside the case.Let us know how it works out.
Old May 3, 2007 | 11:01 AM
T2GTUS's Avatar
Griffin > Good eye! You are correct, it is not wired up yet(nor have the ms board mods been done). I am planning on just using the db25 connector right above the P&H board for the injector wiring, short "U" bends probably so I can still prop the case open at an angle...
scissorhands
Sep 16, 2015 01:25 PM
