Headroom....
Old Mar 25, 2002 | 09:00 AM
phatmonky's Avatar
William
Headroom....
I've read all the posts about fitting into a FD if you are tall, but there seems to be some debate on weather or not a sunroof is a good thing for us tall people.
Some people say to get one and open it slightly for use with a helmet...makes sense, but others say that the sunroof will make less room closed.
Closed, will the addition of the factory sunroof lessen headroom?
Old Mar 25, 2002 | 09:39 AM
ttpowerd's Avatar
HARRRRRRRRR
with the sunroof closed there is less headroom....that is why if you look at 6 point rollcages they typically say "can not be used with sunroof" or something along those lines
Old Mar 25, 2002 | 09:41 AM
phatmonky's Avatar
William
Hmmm, I didn't realize that about the rollcages (which will be a concern later)
Thanks. I guess I'm going to go take a look at the R1 I saw
Old Mar 25, 2002 | 10:18 AM
rswst8's Avatar
no, you do NOT want to be sticking your head out of any sunroof, because if you flip the car then the first thing hitting will be your noggin.
same reason for convertibles with a rollbar, they use a broomstick to check your helmet is below the line between the rollbar and the top of the windshield.
Old Mar 25, 2002 | 02:37 PM
JConn2299's Avatar
reliable performance
The sunroof, when it's closed, decreases headroom by 1.2 inches. That's a significant amount in such a low car.
Old Mar 25, 2002 | 02:48 PM
phatmonky's Avatar
William
Damn! All 6'3" of me already has to squish into ti. No sunroof for me. Thanks guys
Old Mar 25, 2002 | 03:07 PM
maxpesce's Avatar
Ex fd *****
I don't beleive it - My sun roof is barely 2" thick total, the roof & headliner w/o sunroof has to be at least 1.25" I think the loss is closer to .5".
For a tall driver opening the sunroof won't help - the highest pont on your head is BEHIND the Sunroof opening. at 5'-10" My helmet hits just behind the opening unless I lay the seat back an extra couple clicks. I think the real solution to the Headroom issue is to extend the wheel so you can sit slightly reclined and still reach the wheel comfortably.
Old Mar 25, 2002 | 03:15 PM
neo_omega's Avatar
***Moderator***
open sunroof when racing? are you try to kill yourself?
Old Mar 25, 2002 | 03:29 PM
phatmonky's Avatar
William
I'm not, I was inquiring about the previous comments made in all the other threads.
Old Mar 25, 2002 | 03:41 PM
neo_omega's Avatar
***Moderator***
Whoever make that comment about open the sunroof is not very wise. Sunroof already weaken the roof structure. If you have no rollcage and open the sunroof in a race, you know what will happen in the event of a roll over right?
Old Mar 25, 2002 | 04:30 PM
cruser's Avatar
I am 6'2" and was amazed by how big of a difference the sunroof made. When I am in my car (w/sunroof) I can barely slide my hand over my head. I recently drove my friends car (w/o sunroof) and could easily slide my hand between my head and the roof. I also think the exterior of the car looks better w/o the sunroof. The double-bubble effect is much more prevelant.
