need quick answer to an o2 sensor problem
Old Mar 24, 2002 | 09:39 PM
i have an air fuel gauge ....well i was driving home a few minutes ago and it was barely working ..only lean was lighting up and i floored it and then the check engine light came on ..when i let off on the gas the check engine light shut off . so i check all my connections , i unplus the o2 sensor and a metal terminal falls out . so basically the connector is no good . what i wanna know is can i just bypass the connector and just solder the wires together ?
Old Mar 24, 2002 | 09:42 PM
vosko's Avatar
Just Call Me Terminator!
yes
Old Mar 24, 2002 | 09:48 PM
NZConvertible's Avatar
I'm a boost creep...
Replace it with a universal plug from an autoparts store or just use insulated spade connectors. You'll regret soldering it if you ever have to take it off (e.g. exhaust work).
Old Mar 24, 2002 | 09:53 PM
spade connectors it is ...i have some in my garage .
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
Aug 18, 2015 02:46 PM
