Best Intake Finals!
Old Mar 24, 2002 | 07:21 PM
bcty's Avatar
Boost This!
Thumbs up Best Intake Finals!
i am curious about what is the best intake out there and your experences with them... how easy it was to install and your power gains.. and what mods you had at the time.. i want to get this post kept sp all of us can refer back to it.... i am getting the K&N Filtercharger because i am getting it cheep.... so what are your opinions on the...... K&N Filtercharger , Apex , HKS Powerflow , Bonez , rActive... thanks
Old Mar 24, 2002 | 07:25 PM
heres a good link:
ALL THE INFO
http://www.gtrowner.com/induction.html
Old Mar 24, 2002 | 07:27 PM
bcty's Avatar
Boost This!
now we have what the company says now what are everyone elses experences!?!
Old Mar 24, 2002 | 07:33 PM
Bambam7's Avatar
I came, I saw, I boosted.
The HKS Foam sucks.
All the others are just K/N media with different mounts, and they can get away with charging 200 bucks@!@!@!
All you need is a universal K/N cone, and an adapter (for 86-88, none for 89+).. don't pay more than 70 bucks total (with adapter) total... and it's the highest flowing intake out there.
The best way is to make it the straight shot out the TB... a few people have done it here. you get rid of the long hose, and elbow.
Old Mar 24, 2002 | 07:55 PM
custom TID material
was doing some reading on honda DIY CAI (don't ask why) and found out that J.C. Whitney sells aluminzed mandrel bent piping. I'm not sure exactly what aluminuzed means short of it being a light weight aluminum pipe. It's much lighter than the T304 SS mandrel pipe they also sell... anyway, buy a section of this in 45, 90, or 180 degree bends and various ID's. then use some high temp ceramic paint to help heat shield (or insulating wrap).
http://www.jcwhitney.com/product.jhtml?CATID=14721&BQ=
prices are good and I'd say this would make a much better intake than 5 or 6 pieces of rubber and PVC pipe.
I'll post pics when I get mine made. I'm just ordering now though so it might be a while.
Old Jan 7, 2003 | 11:54 AM
Barwick's Avatar
SCCA Rookie
I've made that same intake for my Civic (yeah I know, I've since stopped playing with my beater Civic).. and it works fine. I painted it with ceramic paint and wrapped it in insulating stuff (it's like tape with insulation on the other side). Easy to make, but not easy to make perfectly. You have to cut things EXACTLY the right way otherwise you've got gaps between pipes that is only sealed by the rubber hose, which I suppose would cause turbulence.
Old Jan 7, 2003 | 01:40 PM
Ryde _Or_Die's Avatar
I found one piece that I might be able to use at JC Whitney. But it says swaged(expanded) end. I just need a 3" piece with a 45* in it.
Old Jan 7, 2003 | 04:15 PM
Jimmy325i's Avatar
No longer cares
Aluminized means that aluminum has been bonded to the outside of the steel core. That's exhaust tubing you found.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
