apex boost control solenoid, is this right?
Old Apr 28, 2007 | 06:53 AM
NeedFD's Avatar
R. R. R.
Ok I have the boost control solenoid kit with usage of a Power FC and an hks standard wastegate
Correct me if i'm wrong, here's how i'm hooking it up
-harness to the connector by the uim with the white dot
-two hoses on each end of the solenoid, one to turbo reference and another to the side of the wastegate
-top nipple on hks wastegate not connected.
Let me know if I've messed up somewhere.
Old Apr 28, 2007 | 11:26 AM
GoRacer's Avatar
Speed Mach Go Go Go
Not sure about which connector, since each place I go to changes it and there are three possibilities. I still don't know if mine is correct.
Read up on duty cycle I found one end to compressor and the other to wastegate. I have both nipples connected on my Tial.
It is the exact same solenoid used with the AVC-R and Greddy. So it may be easier to find instructions for those. I think I have the Greddy manual in my garage.
Skeese
65
Mar 28, 2017 03:30 PM
