intercooler nitrous sray
Old Apr 26, 2007 | 08:55 AM
MR.45's Avatar
can anybody shed some light on the intercooler nitrous spray kit. and what are the pros and cons for using it on an FD. I'm on the edge of purchasing one and i just want to make sure it wont be a mistake.
Old Apr 26, 2007 | 12:25 PM
Mahjik's Avatar
Mr. Links
Are you referring to the Ntercooler systems by NX?
Old Apr 26, 2007 | 01:20 PM
gravytraindg's Avatar
I Love Cookies!
if your speaking on th ntercooler sprayers, would help of the strip of for a quick period, but evryone i know hat has it uses co2....same effect....super cheep to fill the bottle,
Drew
Old Apr 26, 2007 | 03:42 PM
Madee's Avatar
Might want to do a search. It has been discussed several times over the last 4 years. You can spray nitrous but then a combustable gas will enter your engine bay. If you use the N-tercooler or CRYO2 kits, they are intended to spray CO2. You end up with lots of CO2 in your engine bay. With stock intake probably no problem. With a single turbo and a cone filter, your going to take in CO2, also not good. I'm installing the CRYO2 system and have gone thru great pains to address this issue. Do a search, it has been debated lots.
Old Apr 26, 2007 | 04:53 PM
OneRotor's Avatar
RAWR
i'd say go with a water misting system over a CO2 or NO2 spraying system. You may have short-term super low temps with either of those systems, but H20 is much more cost effective and will significantly lower temps. Look in the AI section about H20 injection into the UIM, or hopefully Rich will chime in with his expierences.
H20 injection, i believe, allows you to run more aggressive timing, if it's tuned into the system. Alot of people just use it as a helper to reduce intake temps and lower the chance of detonation.
Old Apr 26, 2007 | 04:57 PM
Heisenberg's Avatar
Civilization is crumblin
Are you using an aftermarket intercooler? I would say invest your money into some water injection instead.
Old Apr 26, 2007 | 05:01 PM
RX7LINK's Avatar
RX7FD3S
there is really no con in spraying nos to cool ur intercooler... when its for external use only. it is more effective than water. but does cost some $ to fill up v.s. free water.
i've looked into several kits like NX and others, but just for something external IMO those kits are quite pricy unless ur using it internally as well and just have the sprayer for purge.
I still have a direct port nos kit from my old car sittin in the garage that i'm planning to use this with the purge solenoid just for the IC. so i end up buying this guy's kit. he builds them by order depending on ur IC core size.
http://cgi.ebay.com/ebaymotors/Inter...spagenameZWDVW
its not bad for $80. complete to mount and manually spray. oh, btw.. i'm using this on a front mount. I haven't seen anyone use it for other IC setups.
ls1swap
Jun 3, 2024 03:25 PM
1NSIGHT
Sep 25, 2015 12:59 PM
MILOS7
Sep 18, 2015 03:39 PM
Devon300zx
Sep 17, 2015 03:50 PM
