drag raced my TII again
Old Mar 24, 2002 | 03:17 PM
vosko's Avatar
Just Call Me Terminator!
Angry drag raced my TII again
i went to englishtown for time trials. right before i got there clutch pedal is picking up low and has to be pumped to get pressure. this is a wonderful sign right before i get there. i get my first time trial mess up cause of the clutch wind up with a 15.41 @91.1 mph with 2.6 60FT second time clutch pedals down when i launch smoke everywhere wound up with a nice 18 second timeslip and i noticed on the way there i'm getting a thumping from the rear either suspension or wheels and my new front rotors and pads are super squeeky. what a great day.....
Old Mar 24, 2002 | 03:47 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Geez. I'd go home instead of racing if I was having clutch problems.
Thumping = probably broke your front diff mount
Squeeking = kinda normal with brand new pads and rotors, they haven't bedded in yet
Old Mar 24, 2002 | 04:15 PM
vosko's Avatar
well i drove an hour there figured it was worth a shot. yeah somebody suggested maybe its a broken diff mount but when i launch on the street i get no thumping it only occurs at high speed 80+ mph.... might have to take the GTU to mads
Old Mar 24, 2002 | 07:13 PM
vosko's Avatar
nobody cares
Old Mar 24, 2002 | 07:44 PM
turborotarypower's Avatar
gght
Old Mar 24, 2002 | 09:21 PM
87GTR's Avatar
is this a really a T2 time?
Old Mar 24, 2002 | 09:33 PM
vosko's Avatar
unfortunately yes. you can have the power you want but if the clutch won't disengage you will get nowhere
Old Mar 24, 2002 | 09:36 PM
gsracer's Avatar
EIT
I'm not sure of your mods but if I'm sure you realize that if you lowered the 60' time to a2.1- 2.2 or so you'd easily be mid -upper14's so theres a somewhat positive side
Old Mar 24, 2002 | 09:39 PM
vosko's Avatar
the car stock ran 15.3 @ 88mph. now the car has 3" RB DP, 3" MP, cone intake, panspeed ecu and 11psi of boost bleeding to 7.5psi @ redline. on my first run if i cut a 2.1 rather than a 2.6 60ft ( i normally am around that range) would have been a high 14!!!! there's always wednesday for more time trials just gotta fix the car before then
Old Mar 25, 2002 | 04:29 PM
87GTR's Avatar
sounds like time to change the clutch and the diff mounts and give it 1 more try.
tonka_1956
Sep 2, 2015 05:55 PM
