What do you guys think about these for GSL-SE
Old Apr 25, 2007 | 11:11 AM
85rx-7gsl-se's Avatar
I only have 1.3liters
I was looking at getting these rims for my white 85 GSL-SE and was wondering is the forum had any thoughts. They are 15X6 with a 46mm offset.
Attached Thumbnails What do you guys think about these for GSL-SE-oz-rims.jpg
Old Apr 25, 2007 | 11:49 AM
frisbeedog's Avatar
I'm in love with Daisy
Is your 7 white? There may be to much white going on if so.
Not sure about the offset, kinda sounds to big.
I know when I get new wheels for my GSL-SE I want to have a 7" wide wheel.
I say if you are getting them for a good deal then go for it. Can you test fit them.
If you get them be sure to take many photos so we can all check it out.
Old Apr 25, 2007 | 12:40 PM
I figure your better off with too much offest than too little. With too much, you can just spacer to get the right fit. Too little, the rims will stick out past the fenders and your SOL.
Old Apr 25, 2007 | 06:11 PM
Chemical's Avatar
that offset is poop
stock is like 35 or 38 and if you're going to get new wheels at least get them lower offset than stock
Old Apr 25, 2007 | 09:17 PM
Why would you want a lower offset? The stock offset is 40mm. If I understand correctly, the offset is how far the mounting point is offset from the center of the rim. On a 5.5" rim with a +40mm offset, you have approx. 4.35" backspacing with a 1.15" lip. On a 6" rim with a +45mm offset, you have approx. 4.8" backspacing with a 1.2" lip.That would keep the edge of the rim about the same as the factory 5.5" rim. If I wanted it to est out farther, I could put in a small spacer.
Old Apr 25, 2007 | 10:43 PM
13bpower's Avatar
s4 for life
You are correct sir. If the stock offset is +40 on a 5.5 then +45 on a 6.0 should work, an if it doesn't a little bit of space action will solve the problem.
Old Apr 26, 2007 | 01:32 AM
Chemical's Avatar
edit: nm, have fun rockin your fwd offset trash
Old Apr 26, 2007 | 09:19 AM
I like deep dish rims, but without a widebody or flares, you can't get much of a lip. And
i don't want the rims out past the fenders.
Old May 8, 2007 | 07:36 PM
Ok, I found another set I am contemplating going a little wider and a different style since their might be two much white with the first set. I have been a fan of this style and just found a set that are 15x7, 4x114.3, and 38mm offset. I think they will fit. Here is a pic.
Attached Thumbnails What do you guys think about these for GSL-SE-maxxim-screech.jpg
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
