89 13bt
Old Mar 24, 2002 | 10:34 AM
tur2's Avatar
89 13bt
I got a prject 87 t2. The water is mixing with the oil very well. I found a jdm 89 t2 motor complete for a very good price. My question is will it go into the 87t2 with out any serious complications. I know the turbo and exhaust manifold is different. Is there anything else I should consider before getting this motor. Or will I spend more trying to get this one in than just putting the one made for the car in?
Old Mar 24, 2002 | 10:48 AM
Josepi's Avatar
Despise Enmity
ECU and harness, more but it's early, and I have a hangover
Old Mar 24, 2002 | 03:39 PM
RETed's Avatar
Sure, go for it...
Minor differences - you'll need to reroute the wastegate vacuum line, as your vehicle does not have the capabilities to control the boost solenoid.&nbsp Other than that, the only other minor "problem" is the water temp sensor for the gauge is a male spade on the 1989-1991 Kouki engines, while the Zenki motors have a male bullet.
-Ted
Old Mar 24, 2002 | 05:37 PM
SoloIIdrift's Avatar
that and the OMP will have to be changed from your 87 motor, since the 89 motor uses electronic operation vs. the mechanical OMP on the 87
Old Apr 16, 2002 | 09:02 PM
So??
Originally posted by RETed
Sure, go for it...
Isn't , not having boost control a bad thing ? Is there an additional something that needs to be added for this?
Old Apr 16, 2002 | 10:27 PM
RETed's Avatar
Re: So??
Why?&nbsp It's default to 5.5psi of boost if the car is stock...
-Ted
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
BLUE TII
Sep 26, 2015 10:12 PM
Rx7supra
Mar 18, 2002 07:28 PM
