Sponsored by: CARiD
injector duty cycle for a stock fd ecu
Old Mar 24, 2002 | 02:06 AM
skunks's Avatar
I'm a CF and poop smith
hi, i saw this post in the second gen section, https://www.rx7club.com/forum/showth...ctor+duty+cycle and was wondering if anyone in the third gen section knew anything about it. it mainly talks about the injector duty cycle for a stock ecu for a fc and was wondering if there was any kinda injector duty cycle limitation that stock fd ecu's have? also, is there any other way to find out what the injector duty cycle is other then buying a apexi avc-r or a hks injectordutycycle sensor.
Old Mar 24, 2002 | 08:42 AM
swoop's Avatar
Duty cycle refers to the amount of time the injectors are open vs. the time they are closed. So at low RPM the duty cycle will be low, since you don't need all the fuel that could flow though that injector. At higher RPM the duty cycle will be higher, since you do need more of the fuel that can flow through that injector. Duty cycle is constantly changing, based on what the engine needs at any particular moment.
Some automotive multi-meters have duty cycle measuring capabilities. Go down to your auto parts store and find out.
Queppa
Nov 18, 2024 03:47 AM
sherff
Feb 24, 2019 12:09 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
