Throttle Body Mod-Review
Old Mar 24, 2002 | 01:25 AM
rx7_turbo2's Avatar
Professor D.P
Last weekend I decided to do the throttle body mod, but because of weather I didnt have a chance to drive it till tonight. I thought I would post what I thought about it for those who might not have done it.
Let me start by saying it was the first real mechanical mod I have done myself. I've done the TID mod and such but this was the first time I ever pulled the upper intake manifold myself. With some help over the phone from Chris Ng, and some cutting of that stupid *** 90 degree hose under the throttle body, it all came out OK.
I did what I'm sure is considered the standard throttle body mod. Removal of secondary throttle plates, thermowax, and high idle spring assembly. My idle had been wacky for a few months and I always assumed it was a bad thermowax, which is what prompted the mod in the first place. It went pretty smooth no major problems what so ever. I tapped and plugged the holes from the shaft of the secondary plates, cleaned everything back up and threw it back on the car. Since I re-routed that dam 90 degree hose and by passed the throttle body completely the installation was a snap.
I fired the car up, it idled really high about 2200rpm for a couple minutes then the idle dropped. The car almost stalled out but the ecu seemed to compensate and the idle increased to a rock steady 750. I tinkered with the idle mixture screw and the TPS and all was good.
So what did I think about it when I drove it? Off the line under normal driving it has a touch more hesitation, nothing major though. The real test came when I wacked the throttle in 3rd. Boost came up WAY faster than before. Almost instantanious. I laid into the throttle and blam right up to 12psi I really liked the change. It was like that in all gears, boost came on alot quicker for sure.
It was a cold night here about -10 degrees celcius. That and a combination of either wet or dusty roads ment I had no traction in 2nd gear. I would hold the revs at 3 grand then lay into it in 2nd and the tires would release right away. It was alot of fun.
Summing up I would reccomend this mod to anybody who feels they would like that little bit extra at higher rpm's, or have a high or "hunting" idle problem.
What do others think of this mod?
Old Mar 24, 2002 | 01:34 AM
billy's Avatar
is this mod good for n/a's?
billy
Old Mar 24, 2002 | 09:10 AM
Roy James's Avatar
My cars louder than yours
i did the mod on my 88GTU, not too bad. you can just feel a little kick up top.
Old Mar 24, 2002 | 11:13 AM
von's Avatar
von
I agree. All I did was take out the Throtle Plates for the TB mod. No thermowax yet until I can find a 90 dagree hose. The car did have a little more pull after 6000 rpms.
I would imagine that with the more mods the bigger the difference will be. I just have bonez race pipe catback filter e-fan removed some emisions and luxuries. It was well worth it and u can do it in steps like i do. Plates first and was a sinch.
Old Mar 24, 2002 | 01:35 PM
SpeedRacer's Avatar
Formula Mazda Driver
I've done the whole TB mod on my 90 GTU and definently recommend it. Its not going have as noticeable gains as on a Turbo model, but you will notice the throttle response quicker, and revving up to redline will take a little less time.
Old Mar 25, 2002 | 12:27 AM
billy's Avatar
well then im gona have to do this one soon.
thanks
billy
Old Mar 25, 2002 | 08:30 AM
Wankel7's Avatar
Haven't we ALL heard this
If you are using the BAC valve you don't need to find any hoses. What I did was use the same hoses that were always there. I simply went to Lowe's and bought a barbed connector to put the two hoses together. The one from the BAC and the 90° one. Although, not sure if it will hold. Starting car sometime this week to find out.
James
Old Mar 25, 2002 | 08:47 AM
hIGGI's Avatar
i`ll give it try on my NA motor since before i`ll swap it for TII
i already did TB mod on TII TB, but haven`t installed it back to engine, don`t remember re-routing hoses, could u guys remind it to me ? pictures would be cool...
thanks
Old Mar 25, 2002 | 11:18 AM
Turblown's Avatar
Turn up the boost
i did it, only noticed ii has a rougher idle when cold, but its worth the gains, and it cleans everything up real nice.
Rotary Performance Parts
Old Mar 26, 2002 | 05:52 AM
hIGGI's Avatar
anyone got pictures of modified TB installed on NA ?
Old Mar 26, 2002 | 02:05 PM
Eric89GTU's Avatar
hIGGI - I did mine... it looks a lot cleaner and simpler... Working on my car is easier, and I guess it's weight reduction, too. Response may be better, and idle adjustment has been better since I did it. Starting in the cold was a little odd, but not bad. I'll try and take a couple pictures for you sometime.
Old Mar 26, 2002 | 02:09 PM
hIGGI's Avatar
cool! i would really appreciate it and other guys prolly too, good picture is worth of 3 pages how-to sometimes ;o)))
so take more pix and detailed ;o)
thanks
Old Mar 31, 2002 | 02:30 AM
hIGGI's Avatar
Eric, would u have have some pictures ??
I took my TB down yesterday, it was really dirty, rusted inside and lot of carbon...i cleaned it a bit but didn`t removed front plates yet, i need to know what to do with water hoses coming in and out ;o)
thanks
Old Mar 31, 2002 | 03:15 AM
Agent_D's Avatar
rawr
when i did the TB mod to all my n/a's i run the hose directly from the rear of the water pump to the back of the engine, i bypass the BAC valve's little coolant line and unscrewed it and threw it away, i lost like 2 oz. lolol, it feels good on an n/a, throttle response is definitely better, rev's quicker, and there is a noticeable increase of acceleration from 4500 up to redline and beyond, overall its a good mod, and if you direct that coolant hose directly to the rear of the engine under the manifold your intake temps probably cool down a good 20 or more degrees i would think, good luck
Old Mar 31, 2002 | 06:26 PM
bcty's Avatar
Boost This!
i would love to see some pics ot a site refrence i was thinking about doing this today if i can get some good information... thanks
Old Mar 31, 2002 | 06:51 PM
blu_gxl's Avatar
the whole right up is on fc3s-pro.com just be sure to remember where all the lines go when taking it off i'm having that problem right now and it sucks!
james
Old Mar 31, 2002 | 06:59 PM
bcty's Avatar
Boost This!
thats too bad... maybe you guys should label the lines with masking tape before taking them off!!
Old Mar 31, 2002 | 07:34 PM
blu_gxl's Avatar
don't remind me!
Old Apr 1, 2002 | 11:49 AM
Wankel7's Avatar
I have done the TB mod on my '91 turbo and it starts up and idles at 750rpm. Sometimes want to die but it normally dosn't. That was with a 40° F start last night.
Still breaking the engine in so I can drop the hammer
Just wondering if any of guys stuck your TB infront of a bright light. Did you see much light around the throttle plates? I am having only 11" of HG at idle. Wondering if a gap is a reason?
James
Old Apr 3, 2002 | 04:21 AM
hIGGI's Avatar
still noone with pictures ? :o)
Old Apr 3, 2002 | 04:47 AM
Felix Wankel's Avatar
Super Newbie
http://fc3s-pro.com/TECH/HOWTO/TBM/tbm.html
Old Apr 4, 2002 | 01:34 AM
hIGGI's Avatar
those pictures are from TII TB and does not show TB installed and hoses rerouted..
Old Apr 4, 2002 | 01:52 AM
Project DereK's Avatar
when you take out the gold plates in the throttel body take a grinding bit (metal bit not stone) and port out all that extra **** (pardon my lang) that was seperating the flaps. You dont need it anymore, and it will give you even better air flow. I did this on my Turbo SE and it worked 50% better then the "just take the plates out". So in addition to the mod, if you are daring enough, port that sucker out.
Old Apr 4, 2002 | 04:21 AM
Super Newbie
If you would just go out and do it, its blatantly obvious what to do.
Old Apr 4, 2002 | 06:20 PM
Wankel7's Avatar
I started my car and it was running for about 30 seconds. And I wanted to get out of the car to do something. It wanted to die because it was cold. So I clicked on the AC. The BAC held my idle up for me So if you have a BAC that could help you with cold engine drivability issues.
James
