S-AFC wiring question??
Old Mar 23, 2002 | 06:33 PM
SleeperRx's Avatar
Question S-AFC wiring question??
When hooking up the wires from the AFC to the ECU do you just simply tap into each wire?? I know the AFM signal wire you have to cut to attach yellow and white wire.
Thanks
1987 gxl rx-7
rb headers
rb pulley
apexi n1 exhaust
hks intake
10 mm magnecor wires
streetported motor (mild)
tb mod
Old Mar 23, 2002 | 07:26 PM
rx7_turbo2's Avatar
Professor D.P
Ya the signal wires for the AFM you have to splice, the rest you tap. You can download the instructions from the Apexi website.
Old Mar 24, 2002 | 12:01 AM
Bambam7's Avatar
I came, I saw, I boosted.
Hey- if you have problems with it running rough when cold, etc, PM me.
I've fixed those common problems
The ground are crucial too- Two grounds on one wire, 1 CM apart. Get the instruction fro Apexiusa.com or apexi-usa.com, can't remeber which.
The Shaolin
Sep 14, 2015 07:50 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
