Low coolent buzzer
Old Mar 22, 2002 | 11:11 PM
warp0007's Avatar
Low coolent buzzer
My add coolent light is comming on like 4 seconds after I start the car and the buzzer is going off. Is this sensor the wire above the radiator? Cause I know its full. And if I i play wiht the wire it will stop, then come back on moments later.
Old Mar 22, 2002 | 11:29 PM
ASE_Joe's Avatar
Bad, dirty, loose connection. Try cleaning. If that doesn't work, hard wire it.
Old Mar 22, 2002 | 11:46 PM
Zed's Avatar
Zed
Almost thawed
Re: Low coolent buzzer
Check the coolent level in both the upper and lower rad caps and make sure it's full. Is this on a cold start or a hot start?
The Add Coolent light/alarm is not called the "Buzzer of Doom" for nothing.
Z
(cooked a motor last year because of low coolant)
Old Mar 22, 2002 | 11:55 PM
SonicRaT's Avatar
Super Raterhater
If you want a temp fix if your sensor is bad/or some other reason you can just ground it. But check your connections and wires first, it's quite a tiny little wire and looks like it could break easily.
Old Mar 23, 2002 | 01:14 AM
Bleed the air out of the system. This happened on my car. There is an air bleed valve on the top of the passenger side of the radiator.
Old Mar 23, 2002 | 01:16 AM
Woops. Didn't read your entire post befor I posted. Sounds like a bad connection. That sensor grounds when water hits it. Test it by pulling it out, and grounding it against something metal, and see if it goes off.
Coochas
44
Nov 5, 2019 11:08 PM
LongDuck
Oct 7, 2015 08:12 PM
